Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Maytag msd2556aew Not getting wter to ice maker or drinking dispenser. Changed all water,ice and filter solenoid valves and still no water. Could it be the dispenser board?
  • 1 more comment
  • utog196 Feb 15, 2008
    Everything was working fine up to a few days ago. I was getting water and all of a sudden it stopped. Checked the water flow from the pipe coming off the saddle fitting and it was good. Thats when I decided to change the valve solenoids. But that didn't work. Any other ideas? Thanks.
    it is copper.
  • Anonymous Sep 13, 2008
    ice mker makes ice, front door dipenser is dead...
    President:
  • 1,314 Answers
No ice maker on its own circet how are you hooked up to your house saddle valves plastic pipes turn your main line off take it loose get a bucket turn it on and check the flow
Posted on Feb 15, 2008
  • robert samples Feb 15, 2008
    is your pipe where the saddle is connected plastic or copper
No water to ice maker. I want to check the water solenoid to see if it is getting power. I don't have a diagram. is it a 120 volt solenoid? and when does it get the signal to open and allow water into the...
The water control valve gets its signal from the ice maker itself. Then begins the cycle of about six different functions until the ice ejector forks go to the position you see most (home) Then it tells the water control valve to open for about seven (7.5) seconds. You may test the true voltage from the female connection with a OHM meter set to AC voltage. Just have someone press the dispense water control. You can also check each sides coil windings for resistance or OHM's and they should be the same or very close to the same. Use care in the area of the coils and make sure the wires are not wet. One of the two wires for each side may be active even without pressing dispense or having ice maker call for water. Another thing I noticed is that you have two sets of water control valves. The problem is about as much with the Primary Water Control
Valve Part Numbers=> 12544002 and Secondary Water Control Valve => 12002193
as is the=> D7824706Q Ice Maker Module Whirlpool now owns Amana, Maytag, Jenn-Air and Samsung will not let me post their manuals to the public. I can answer your questions as need so If you need more answers or diagrams or photos Click Here=> Sea Breeze If you have any questions please ask, Thanks, Sea Breeze
Amana DRS2660BW Wiring Diagram
Amana DRS2660BW Ice Maker Parts Breakdown
Dec 14, 2010 | Amana DRS2660B Side by Side Refrigerator
I have a GE Refigerator (PSF26MGWA WW). the ice maker will not fill up with water. The tray heats up and the sweeper works. The fill solenoid for the ice maker does not work properly.The drinking water...
the ice maker is in control of the valve, however, the valve is one assembly containing the valve for the water dispenser and the one for the ice maker, take your model to the appliance parts store and get you a water valve assembly for your model number.
Dec 23, 2017 | GE Refrigerators
What to do if water does not dispense from water dispenser
A couple of things to check: If equipped with an automatic ice maker - is ice being made? If so, the water supply to the fridge is OK. If not, look for a problem in the supply line (is it kinked, crushed, or is the water shut off)? Is the filter clogged? Some fridges will pass water w/o a filter installed - see if your will by removing the filter and try to get water from the fridge.
If ice is being made, the problem lies with the water "circuit" in the fridge (the solenoid, water lines, filter etc.). When water is dispensed from the fridge into a glass, a small solenoid valve on the drinking water line opens to allow water to flow. Many times, you can hear the "click" of the solenoid valve both when it is opening (on) and closing (off). If you used to hear it, and now no longer can, it indicates a problem with the electrical circuit that is activated when you try to dispense water. This electrical circuit consists of the switch, wiring and solenoid coil itself. The wiring will seldom fail - but those parts that physically move (the switch and solenoid) are very likely candidates for failure. You should obtain the schematics for your fridge and get a volt meter to troubleshoot the switch and solenoid. Of course, you could purchase both the switch and solenoid and replace them one at a time; and have a reasonable expectation that one will probably solve the problem.
Mar 31, 2010 | Refrigerators
Maytag Model MSD2651HEW - Changed Filter and
try checking your water resevioir it sits behind the drawers and sometimes gets ice crystals in it
take a hirdryer to the water lines that are exposed for a few minuts this might help
Oct 12, 2009 | Maytag MSD2651 HE Side by Side...
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
Water dispenser no longer works.
Where the water supply connects to the Ref there is one water valve but, two solenoids. One for the water and one for the ice maker. An OHM meter will tell you if these solenoids are good.
Solenoids good;
Set the meter to volts and check if power is getting to the water solenoid while pressing the water despensor. No power, bad switch.
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Gs2728 fidge freezer with water dispenser The water dispenser dispenses water on it's own at any time all over the floor
The ice maker water solenoid is dragging the voltage down on the electronic control board. Disconnect the solenoid and see if you can select the ice, crush and water using the panel buttons. If thats working fine then the water valve needs to be changed.
Jul 27, 2008 | Maytag Refrigerators
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
NOT ENOUGH WATER.
Check to see if the water line is kinked or if the valve is partly closed.next check to see if you have some blockage in the line. Shut the water off, remove the filter element,if you hace one and blow air in the water dispenser. If that doesn't do it, remove the line after the shut off, and blow air in before the filter. if all is good you may have to replace the water valve solenoid. Is your ice maker making ice ? if not it is not getting water either. let me know if this helps..
Sep 09, 2007 | Maytag MSD2436GR Side by Side Refrigerator
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
270 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
