Question about GE 29487GE2 Corded Phone
Error:Inhibited I often cannot pick up a call on hold or get line 1 to activate and the LCD displays: error: inhibited. I have to unplug the power and reset the phone to solve the issue. Any help is much appreciated.
  • humble p Jul 01, 2008
    I have the same problem as Mike57's. When I try to dial out on line one I get error inhibited and I can not answer line 1 on that phone. It does not even ring on that phone but on line 2 I can dial out and it rings in. Please contact Paula at jonesandjonesllc@bellsouth.net.
    Thanks
Unplug the phone, remove any batteries, and unplug the phone cord, wait ten minutes, and replace batteries, plug it back in and it should reset it.
Posted on Jul 08, 2008
How do you turn error code light off on a kubota l3901
Mode "A" (Test Mode)
1. While holding down both DPF INHIBIT switch and the parked regeneration switch, turn the key switch to "ON" or "START" position.
2. Mode selection display is indicated on the LCD.
3. Press the parked regeneration switch and the mode indicated on the LCD is changed.
4. If "A" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Test mode is selected.
6. If parked regeneration switch is pressed, the display item is changed.
7. Turn off the key switch to finish test mode.
Mode "b" (Error Information Clear Mode)
1. While holding down both DPF INHIBT switch and parked regeneration switch, turn key switch "ON" or "START" position.
3. Press the parked regeneration switch and the mode indication on the LCD is changed.
4. If "b" is indicated on the LCD, press the parked regeneration switch for more than 2 seconds.
5. Error information Clear mode is selected and the expression "PUSH" is displayed.
6. Press the parked regeneration switch for more than 2 seconds.
7. The expression "OFF" is displayed.
8. Turn off the key switch.
Be sure to clear error information by performing this procedure after servicing is finished.
Jun 13, 2015 | Kubota Garden
Check engine light is on. Does replacing the oil filter fix the problem? The codes are: P171, P174
very Unlikely this will have any affect. sounds more like an air leak to me.
You will find all codes available at http://www.bluejag.co.uk/decode.php
Fault Code:- P0171 Indicates a Power-train fault
The fault is generally due to a problem in the Emission Management (Fuel or Air) area
Fault Description: Bank 1 combustion too lean
Action of ECM:- ECM Default:- Bank 1 catalyst warm-up ignition ****** inhibited- Bank 1 closed loop fuel metering inhibited- Canister purge inhibited- Maximum engine speed reduced
After clearing the DTC, complete the Start engine and bring to normal operating temperature> 82 °C (180 °F) Idle for 10 minutes
Check for a reoccurrence of fault DTC.
Possible Fault:- Engine misfire Air intake leak between MAF Sensor and throttle Fuel filter / system restriction Fuel injector restriction Low fuel pump output HO2 Sensor(s) (1/1, 1/2) harness wiring condition fault Exhaust leak (before catalyst) ECM receiving incorrect signal from one or more of the following components: ECT Sensor, MAF Sensor, IAT Sensor, TP Sensor
Fault Code:- P0174 Indicates a Power-train fault
Fault Description: Bank 2 combustion too lean
Action of ECM:- ECM Default:- Bank 2 catalyst warm-up ignition ****** inhibited- Bank 2 closed loop fuel metering inhibited- Canister purge inhibited- Maximum engine speed reduced
Possible Fault:- Engine misfire Air intake leak between MAF Sensor and throttle Fuel filter / system restriction Fuel injector restriction Low fuel pump output HO2 Sensor(s) (2/1, 2/2) harness wiring condition fault Exhaust leak (before catalyst) ECM receiving incorrect signal from one or more of the following components: ECT Sensor, MAF Sensor, IAT Sensor, TP Sensor
Sep 09, 2011 | 2004 Jaguar X-Type
I would like to know what the following codes represent for my 2002 jaguar x-type 3.0 Codes are P174, P175, P1111
P1110 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit
The other DTC refer to mixture issues.
From http://www.bluejag.co.uk
Action of ECM:- ECM Default: - Bank 2 catalyst warm-up ignition ****** inhibited - Bank 2 closed loop fuel metering inhibited - Canister purge inhibited - Maximum engine speed reduced
Possible Fault:-
once again from http://www.bluejag.co.uk
Fault Code:- P0175 Indicates a Power-train fault
Fault Description: Bank 2 combustion too rich
After clearing the DTC, complete the Start engine and bring to normal operating temperature > 82 °C (180 °F) Idle for 10 minutes
Possible Fault:- Restricted air filter Leaking fuel injector(s) ECM receiving incorrect signal from one or more of the following components: ECT Sensor, MAF Sensor, IAT Sensor, TP Sensor
Apr 23, 2011 | 2003 Jaguar X-Type
Outputs of TI analog 500-5016 do not change when inputs to Ti 520 controller are changed. Mother board consists of power supply , TI 520c controller, TI 500-5016 analog output, TI 500-5009 analog input,...
hi, The VERY first thing we MUST check, is the PSU, check this exhaustively, even if possible replace with a know good, as if this isn't 100% A OK, NOTHING else can be..then well ADC 101 says that if there is NO output from the ADC, then this can only be due to 2 reasons, one, it is Inhibited, two, there is NO DATA to be converted/coming out? We need to find out why?
You need to use a 'scope and view the input and output signals along with the lines that control the IC, data flow, Inhibit etc, and see if all the lines are in the correct logic states, work back along either the control lines or signal, and work out why either it is inhibited or lacking signal.
Also check that you micro, isn't inhibiting it either?
Start at the beginning, where the analog signal is presented, and follow a line(s) along through the circuit with the 'scope, checking where they enter the conversion IC, then look at the Output(s) and see whats what, now if all control lines are set OK, and there is NO output then that IC must be faulty... anyway follow the signal along and see why it's not working..
unfortunately there could be many, many conditions that can cause this type of thing, one simply? must work through each block of the circuit, isolating sections if possible and viewing the activity on a 'scope to see where it all goes wrong. checking the voltage and signal levels are correct.
Mar 20, 2011 | Texas Instruments Computers & Internet
Have a prestige remote start that was installed and only worked for one week. now the remote beeps but doesn't start or lock/unlock any doors. remote says inhibited . all doors are closed as is hood and...
If this is the Prestige 997C, there is a remote starter disable feature that can be activated through the programming switch. When it is active it will display "inhibit' on the screen. To deactivate this feature, press and hold programming switch, turn key on, off, on, off, on then off. When the hood pin switch is not making contact with the hood when closed, the screen will display inhibit. When the brake shutdown wire is active the screen will display inhibit.
Feb 27, 2011 | Prestige Remote Start
The intercom button keeps flashing red and green and it will not let us use it. It says Error: Inhibited
If you have more than one phone then its probably flashing because the phone ID is the same as another phone on your system or not setup up yet with an ID just has two dashes (--). or you if you have more than one phone on the system and have more than 2 lines coming into the phone, they all have to be on line 1 together in the first port on the back. Communication between sets are done on line 1
Oct 01, 2010 | RCA 25413RE3 Corded Phone
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
RCA phone
I'm trying to get phone ID working and also the intercom working but have had no luck. I also get the "error:inhibited" message.
Jul 14, 2008 | RCA 25403RE3 Corded Phone
GE 29488
Note: Intercom features are NOT compatible when DSL is installed on line 1.You may need to reconfigure it for dsl internet if it is installed on line 1
May 27, 2008 | GE 29488GE2 Corded Phone
GE 29487GE2 Corded Phone Logo
2,182 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
