Question about Indesit 24 in. D61 Free-standing Dishwasher
Lights flashing on dishwasher and not working!
The dishwaher isnt working two (of the four) green lights on the top left are flashing, tried different settings but still flashing its the end light then third one in? Please help?.x
Kindest Regards
Christina
  • hoistor Aug 11, 2008
    this a built in d1620 dish washer and 1 have led 2 and 4 flashing any ideas as this error code is not in manuel cheers
    Sergeant:
  • 236 Answers
Put some towels dowm and tip the d/w over to one side about 45 degrees if water pours out of the base it means that the d/w is in "flood mode" and you have a leak into the base that will need resolving.
Posted on Feb 16, 2008
Turn signal
because of no light flasher on left side the front one will go faster .maybe the left rear light is burn. and brake lights are control by the brake switch on brake pedal hardware, might be unadjust
Sep 12, 2013 | 2001 Pontiac Grand Prix
The green start light is flashing and won't start again when pressed.
Cycle thru the wash settings. Do all the lights work for the different settings?
Nov 25, 2012 | Washing Machines
Green light flashes 9 times will not go
Hi. Different brands of controllers give different fault codes.If this is a dynamic controller, 9 flashes is the code for a faulty controller. This does not always mean that the controller is actually at fault.
It could be a burn't out brake solenoid, that now has a different resistance through the solenoid coil.
You mention the middle speed green light is flashing, normally on dynamic controllers, it is the most left battery level LED that flashes. You might have a different controller.
Have a look under the panels and let us know what controller your machine has.
You could try the agents, and see if they can tell you what the problem is.
Good luck. Neil.
Jun 06, 2010 | Golden Technologies Companion II Travel...
Green light, followed by yellow light flashes 5 times, then green again. Print screen says operator error, press printer's resume button.
Hi there
You can try not really know but it like your waste ink needs to be reset.
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Wait until print head stops moving
5. Press RESUME four times (if four doesn't work try three times)
6. Press POWER once
7. Press RESUME four times (if four doesn't work try three times)
8. Press POWER once
Repeating the RESUME/POWER code twice made the difference, the fixes I found wouldn't work because they stopped at step 6.
Feb 12, 2010 | Canon I960 InkJet Photo Printer
Lights flashing at end of cycle, dishes not clean
I switched it off at the wall and left it for a minute and set the dial to Stop and then set it again from the beginning and so far it has been fine. Thanks, DCD
Oct 02, 2009 | Miele Dishwashers
Battery light green, then flashes four times red, repeats
remove the battery
clean the connecting ends of ur laptop & battery,
plug it back in & then start it...
Aug 27, 2009 | Dell Latitude D600 Notebook
Sound works but no image
This means the AV cable is not detected, try one of these...
1. Make sure that the AV cable is correctly connected to the Xbox 360 console.
2. Disconnect the AV cable from the Xbox 360 console, and then reconnect the AV cable to the Xbox 360 console.
3. If the four flashing red lights continue to flash, try wiping the metal area of the AV pack with a dry cloth. The metal area is the end that plugs into the console. Wipe the metal area thoroughly, and then try the AV Pack again.
4. If the AV cable is correctly connected but the four red lights are still flashing, substitute a different AV cable if you have one available.
If this is helpful at all, please rate, thanks!
Nov 24, 2007 | Microsoft Xbox 360 Console
Flashing green power light
Verify Model # on back of set ends with....13. If so, then
replace four capacitors in DM module...1000mf 25v 105 degree.
If not,solution will be different....................T.
Aug 21, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Indesit 24 in. D61 Free-standing Dishwasher Logo
280 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
