Question about Canon PIXMA MP160 All-In-One Printer
Error code 2 And 7 . How to solve
Error code 2 and 7. The printer hang+cannot out the catridge when pull up the case.. Help me... Still have warranty or not...coz not less than one year
  • SnapSurveys Mar 25, 2008
    I'm experiencing the exact same thing as wannabeme82. Right now the Alarm light is constantly blinking orange. The LCD screen keeps flashing, "E .. 2 ....7" . And when I try to print something a message pops up that says, "The ink absorber is full. Contact the service center". I have know idea what or where the ink absorber is, or who to even contact to get this fix. Basically the printer is useless at this point. Please help.
    Thanks
  • 57 Answers
The ink absorber is a pad located at the bottom of the purge unit if you cannot find a Canon representative i can help you reset to you would be able to use it just follow these steps
-Plug the power cord in
-Press the Power button and hold it down when it lights up press Resume twice still holding down the power button then release both buttons
-Wait momentarily when "0" appears on the display press resume 4 times then press the power button wait about a 2 second then press the power button 2 more times and your printer should be usable again
GoodLuck
Posted on Jun 10, 2008
Carriage slams into left side
In this case unplug the power supply from the Printer........... 1. Open the Printer Cover.......... 2. Remove both the Catridges from the Printer............ 3. Move the Catridge Carrier which holds the catridge from right to left and from left to right for about 10 times............ 4. Try to make a copy without the catridges........If this works and it gives a Blank Page out............ 5. Insert both the catridges turn the printer off and turn it on again........... 6. Now it should work fine........ Good Luck......
Feb 22, 2013 | Lexmark Z600 InkJet Printer
HP Photosmart 3210 -Ink System failure - Error 0xc18a0001
In addition to having the ink system failure error 0xc18a0001, my printer screen also read improper shutdown. After trying most of the above solutions with no success, I did a search for the improper shutdown problem. This is where I found my solution!
The solution is under "Printer will not start" the solution post is by speters9971. "...you can try a sem-full reset to factory default conditions by 1. unplugging the power cord while the printer is powered on and 2. press and hold the OK and Cancel buttons while plugging in the power cord."
This is what solved my problem after hours of searching & repetitive similar solutions!!! The above solutions did not help; some of them seemed to be incomplete or irrelevant for my model. I have a HP Photosmart 3210 All-in-One.
Thank you speters9971!!!!!!!
May 27, 2008 | HP Photosmart 3210 All-In-One InkJet...
Service error 6500 ix4000
The Canon website indicates that is a hardware problem, there's nothing i can do. You call a technician or the canon help support. This is the description of the code:
Other hardware error [6500] - Logic board ***'y (QM2-3393 / QM3-1654)
Mar 02, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Error code 1203
it is catridge error kindly replace the catridges.
Nov 24, 2009 | Lexmark P450 InkJet Photo Printer
Cartridge error 50c
The most usual solution of this error is to change the catridges ( both ). But it also can't work in some cases. In that case try to locate the protective tape on the catridges. If the tape gives off a sticky stuff onto the catridge contact, the error can come. Try removing the sticky material.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Lexmark X6150 All-In-One InkJet Printer
Paper jammed. Once pulled free and clear, it
if you pulled the paper out of a jam and it was not done correclty
5100 is a Carriage Home Position Error.
try cleaning the plastic strip that runs the length of the carriage, it may be contaminated.
Use alcohol and a swab.
Check the lever for the catridge. sometime the catridge does sit properly in the carriage and it will hitt the side of the front cover when it moves. Push the catridge in place to try solve the problem.
Aug 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Dell 946 error 1203
In this Case just unplug the Power Supply from the Printer...........
Remove both the catridges from the Printer........
Move the Catridge carrier which holds the catridge back and forth for abt 20 times as fast as u can....
Now Turn the Printer On it will work fine.........
Good Luck...........
Apr 04, 2009 | Dell 946 All-In-One InkJet Printer
Hardware error 0502, how do I fix this? What causes it?
It happpens when the Catridge is unable to Communicate with the Printer............. In this case what i would request you to do is............... Unplug the Power Supply from the Printer When u remove the cover of the Printer behing the Catridge carrier which holds the catridges u will see a thin long transparent strip which looks like a Tap........... Take a Dry Paper Towel and Gently wipe that tape from right to the left it is very delicate so pls do it gently............ Now Take out both the Catridges from the Printer.............. Move the Catridge carrier which holds the catridge, From right to the Left and From Left to Right for abt 10 Times............... Now u can insert both the catridges in and Turn On the Machine.......... Good Luck
Jan 31, 2009 | Lexmark X6170 All-In-One InkJet Printer
Printer MP160 service error 5010 after refill catridge
I had refilled the catrige, then when I start to print a 'service error' window will appear. At the LCD screed shows E.. 4 ..2. I believe the printer simply assume the catridge is depleted, but how can it happened as I already just refilled it.
How to make printer detected the catridge as a full? I really hope you can solve and make my refilling mission succesful and my printer work again.
Aug 13, 2008 | Canon PIXMA MP160 All-In-One Printer
Error code
Hi Jakabi. That error code means there's a defective module in the printer. It's not user replaceable, unfortunately. The only solution is to contact the store where you bought it, or Canon's tech support to get a replacement. That comes directly from Canon support ! I know it isn't what you'd like to hear, but unfortunately it's the only way out of it. Thanks ! cheebster.
Jun 20, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One Printer Logo
29 people viewed this question
old marine
old marine
