Question about Canon imageRUNNER 600 Printer
Document feeder for Canon Imagerunner 600
We are looking for a replacement document feeder for our Canon Imagerunner 600.
Q le paso al de ustedes
para poder sugerirte
Posted on Oct 13, 2008
Check document error, no paper jam
It may be a bad hinge on the document feeder. I have seen several times where the left hinge ( when looking at machine from front) does not close all the way. Close the adf and look at the gap between the copier and the adf. The gap should be the same from the front to the back. If the gap is bigger at the rear ( when looking at the left side of the machine) then you need to replace the left hinge. You can also try pushing down on the document feeders' left side as it feeds the paper. if it works while pushing down, then it is the hinge.
Sep 05, 2012 | Canon Imagerunner 1025n
There is a black dotted line whenever I make copies on the cannon imagerunner 400s
It's either a speck on the scanner glass for the document feeder, or a smear of toner on one of the rollers. Check the skinny band of glass inside the document feeder for specks and clean it with a lint-free soft cloth and a little rubbing alcohol or a very little bit of water.
May 30, 2012 | Canon imageRUNNER 400S Copier
My Canon ImageRUNNER 3225 does not print correctly aligned when sent through the feeder? When feeding paper, I have tried Landscape and the resulting copy is cut off from the top and bottom and the left...
Is it ok when you just put the document on the glass? If so, the Document feeder needs a whole set of rollers.
Otherwise the document scanner may be bad. This needs to be changed out by a technician.
Whit
Item, Inc
Sep 15, 2010 | Canon imageRUNNER 3225 Black and White...
Canon Imagerunner 220- Autofeeder not working
there is the possiblity that the document feed rollers and seperation pads are dirty and need cleaning and or replaced. and or the clutch that turns the rollers is slipping or burned out.
i would start with the rollers and pad they are least expensive and easiest to replace.
May 28, 2010 | Canon imageRUNNER 2200
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
I have a problem with the error e 051 some body help me
000 Fuser problem E010 Main motor, motor board, clock pulse E030 Counter E050 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E204 Document sensor, scan reverse sensor or scale E210 Lens problem E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
Jan 15, 2010 | Canon imageRUNNER 400S Copier
Canon 1023if auto feeder not working. Says check
The document feeder has multiple sensors in it. sometimes they hang up and stay stuck out of place. Other sensors might get paper dust on the face of the sensor. If you can open the document cover, locate the sensors and see if any are ajar or the sensor flag fell out of place. Also look to see if a paper is stuck in any of the paper path areas. Not seeing the machine it is hard to say if it fed paper and says check document, if it did, clean the feed wheels with a wet paper towel.
Oct 15, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon IR 105 Will Print from Network and Fiery but won't copy
So, the feeder will not pull in the paper, If this is the case, check the throat of the document feeder for foreign objects, (staples, paperclips, post it notes, or signature flags). you can clean the rollers with alcohol, and blow out the document feeder with compressed air. (Computer Duster)
Hope this is of some help.
Ed
May 06, 2009 | Canon imageRUNNER C3200 Copier
Canon D860 - I get a solid black line when I use paper feeder.
I'm pretty sure you might have solved this problem already, but this might help others.
Make sure that the platen glass is clean near the right side of the machine, where the document is scanned when going through the document scanner. Remember, when placing a document on the glass to copy it that way, you would place it on the glass on the left side of the machine. When scanning through the ADF, the scanning unit itself moves to the right side of glass and scans the document as it moves through.
We had the same issue and found out that there was a little spec of dirt on the glass. After cleaning it, the problem was solved.
Feb 03, 2009 | Canon ImageRUNNER 1670F Copier
Accessories for Canon irc 3170i
these people can get you what you need , if you want someone closer just search around for copier wholesale companies.
Jan 10, 2009 | Canon ImageRunner C-3170I Copier
Canon imageRUNNER 600 Printer Logo
149 people viewed this question
old marine
old marine
