Overriding 'Call serviceman ' error
Hi, i have an old Fax machine, that comes up with a 'call serviceman' error, i have heard it is possible to override this, i just need to know how...please
  • 63 Answers
Why does my fax machine display the message CALL SERVICEMAN?
A mechanical failure of some sort has occurred, and you probably will need to call a fax repair technician. On certain models, this message indicates the machine overheated for some reason. Turn off the power switch (or disconnect the power cord) and let the machine sit idle for 5-10 minutes.
Posted on Feb 15, 2008
What Could Be The Failing Component On My Machine With Displays SC: 552 With An Error Message "Turn Off Main Switch And Then On" ?
I am no expert, but it potentially could be a memory chip error being a laser printer, very common, these can be easily and cheaply be replaced as there is usually an access hatch to the side printer memory isn't usually very high capacity
Jun 15, 2014 | Ricoh Nashuatec MP1600 Toner 9000 Yield...
Error 386
Hi Error 344,
Is telling you the remote end has hung up the call which means it may not be a fax number (you called a voice line number for example, you can confirm if it as fax by just calling the number on your phone if you hear the whistles of a fax then that's not the cause).
I'm not familiar with the HP model but if it is "Super Group 3" (you can tell this if the transmission speed is capable of above 14.4kbps) and you're trying to call an older fax the remote machine may not be able to recognise the "Calling tone" your machine is sending and so it hangs up. You can try to remedy this by temporarily disabling Error Correction Mode (ECM) in your machines fax set up menu this will disable the Super Group 3 capabilities of the fax and maximum transmission speed will be reduced to the older Group 3 machine. HP website recommends the following:
Error Code: 344, 345, 346, 347, 348, 349 ECM, 350 ECM, 351 ECM, 352 ECM, 353 ECM, 354, 355 Definitions
  • The remote machine failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power-related problems.
  • The call-waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
  • The remote user pressed the Stop key while the reception was in progress.
  • Under rare conditions, incompatibility between the two machines might cause the remote machine to abandon the call.
Solutions
  • Retryt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
  • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved.
  • Try sending at a lower transmission speed.
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Jan 23, 2014 | HP Officejet 6600 e-All-in-One -...
What is an error 283 on a hp officejet J6400
Definitions
  • A communication failure occurred between the two machines.
  • The user at the remote machine might have pressed the Stop key.
  • The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line. Do not use call waiting on a line with a fax machine.
  • The power at the remote machine was interrupted, or deliberately turned off causing the fax session to be interrupted.
Solutions
  • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM (c00060802) (in English).
  • Set the host machine to receive at a slower transmission speed.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems
    Aug 31, 2011 | Office Equipment & Supplies
    Muratec F-320 Super G3 we are getting a fax ready Please call Service message
    Please Call Service means the machine "thinks" it has detected a fault.
    To check do the following..
    Press PROGRAM,*, 6
    Then press PROGRAM to select Service Call mode, then press ENTER....the error message will be displayed in the display.
    Most common error given machine age was "Heater Error".
    If this is the case you will need a Serviceman to do repairs to the Fuser Unit.
    Oct 25, 2010 | Muratec F320 Plain Paper LED Fax
    Fax thru Internet help
    Magic Jack is lying to you. ALL fax machines are Analog devices, Magic Jack is Digital
    Jun 21, 2010 | Muratec M1250 Fax
    Error 351
    • The following is for error code 351
    Solutions
    • Disable ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to send the entire document will be improved. Try sending at a lower transmission speed.
    Mar 01, 2010 | HP FAX 1250 Fax Machine (Black)
    What is the meaning of eror 232*
    Error Code: 232
    Solutions
    • If the error persists, and error correction is in use for the fax session, disable ECM. Fax quality might be degraded. Click here for instructions on enabling and disabling ECM .
    • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power brownouts and other power-related problems.
    Nov 04, 2009 | HP OfficeJet J4580 All-In-One Laser...
    Error code 345
    The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted.
    Number of possible causes, check the phone line, try a different fax number for a start. Is there other fax machines in the office on the same line
    Sep 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
    HP office jet 6210 All - in- one /error message 232
    Please consult this page for links to fax error codes for your printer.
    In particular, Error 232 yields this info:
    Error Code: 232, 233, 234, 235 ECM, 236 ECM, 237
    Definitions
    Solutions
    You can also access the home support page for your printer here., in case you should have further troubles.
    I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
    If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
    Jul 24, 2009 | HP PSC 2410 All-In-One InkJet Printer
    PSC 2000 Series 2410 HP all in one
    Hi this error code is for:-
    The remote fax machine is attempting to receive instead of send. Both machines have attempted to start a reception at the same time. It is possible to accidentally initiate a fax reception after dialing on many fax machines, if there is no paper in the machine or if the paper is not correctly loaded and cannot be sensed by the appropriate document sensor.
    *Contact the sender to ensure that a document is ready and correctly loaded in the transmitting fax machine and that the remote machine is attempting to initiate a transmission and not a reception.
    Apr 08, 2008 | HP PSC 2410 All-In-One InkJet Printer
    95 people viewed this question
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
