Question about Sony MHC-RG222 CD Shelf System
Sony MHC-RG222 cd player broken
A loud noise comes from the cd player as if it's trying to spin too fast. The spinning is even present when on standby. Also it seems to have slowed the enitre system down, taking a while for commands from pressing buttons to be recognised.
  • Ben08 Feb 15, 2008
    It's not really a problem with the sound- it seems more mechanical. The noise is coming from the cd spinning machanism. Also the player doesn't actualy work- it just spins the cd without doing anything else!
  • 281 Answers
It is not clear from your post that whether this is functioning perfectly other than the sound problem, if it doesn't, change the laser pick up.
Posted on Feb 14, 2008
Mhc-rg222 red light blinks power button wont turn on unit
Check the back of the unit for speaker wire shorts, if everything looks fine suspect the output ic's in the stereo.
May 26, 2012 | Sony MHC-RG222 CD Shelf System
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
When on a fast spin it is extremely loud, too loud...
Water in bearings causes rust, and rust in bearings creates noise...This is the most likely reason for the noisy spin....Check for any slop in inner drum....Bearings and seals and likely the shaft probably need to be replaced....Quite a big and complex job....Good luck....Nomess
May 18, 2010 | Washing Machines
Sony 3 disc changer mhc-gx880 has broken belt. How to manually eject disc tray?
You have to open the unit with screws in the back and push it out by hand, there should be a series of gears that you have to spin for the tray to come out. You may be able to gently push it by hand to come out.
Jan 24, 2010 | Sony MHC-RV888D Shelf System
How to connect MHC-RG222 speakers to my pc
If you have an output function at the back of your mini HIFI then surely you can.What you need is a Dual RCA [from the mini HIFI] to 3.5 mm Stereo Jack [to the PC]. The cable is easily available in the market...go to this site n you'll get the idea http://www.vpi.us/cable-audio.html
Jun 17, 2009 | Sony MHC-RG222 CD Shelf System
Water does not drain, strange noise while in spin cycle
sounds like something is stuck in your drain system. Most likely just in front or even in the pump
Please check this
Apr 22, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Sony MHC-RG222 CD Shelf System Logo
247 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
