Question about Linksys Wireless-G WRT54GS Router (e125894)
Linksys wrt54gs brough it of cash converters got to coneckt to lab top it wont let go to web page
  • Matthew Page
    Matthew Page May 11, 2010
    You have recently purchased this equipment and now your laptop will not open Internet web pages? Is that correct? Is the problem only resident on your laptop, and other machines in your home are ok?
Open your webbrowser and type in your routers ip adress... by default it is 192.168.1.1.. default username and password is 'admin' configure your wi router and you should be ready to go...
Posted on May 03, 2008
The Cisco System logo just stays orange, I attempted to repair on my lap top but it won't let me repair.
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
To perform a hardware reset on your Linksys router, follow these steps:
Step 1:
Take note of the current settings of the router before resetting.
Step 2:
Press and hold the Reset button of the router for 30 seconds.
Figure 1: Location of the Reset button on a Linksys BEFW11S4 router.
NOTE: The image may vary depending on the model number of the Linksys device.
Figure 2: Location of the Reset button on a Linksys WRT54GX router.
Figure 3: Location of the Reset button on a Linksys WRT54GC router.
NOTE: If the image of your router looks different from the ones shown above, consult your router documentation.
Step 3:
If the normal reset does not work, try to press and hold the Reset button for three seconds. The Ethernet light should go OFF then back ON. Unplug and re-plug the router's power adapter while pressing the Reset button. Keep holding the reset until the power light stops blinking.
NOTE: The router must be powered ON when you press the Reset button.
To reset the router via its web-based setup page, follow the steps below.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the router's web-based setup page using a Mac computer, click here.
Step 2:
When the router's web-based setup page appears, click Administration then click on Factory Defaults.
kb4008-004_en.png NOTE: If the screen on your router's web-based setup page looks different, click here.
Step 3:
Click on Restore Factory Defaults and select Yes.
kb4008-005_en.png Step 4:
Click OK.
Related Articles:
Accessing the Router's Web-Based Setup Page
Setting-Up a Router with Cable Internet Service
Setting-Up a Linksys Router Using DSL Internet
Changing the Linksys Router's Password
Nov 09, 2010 | Linksys Wireless-G WRT54GS Router...
Tip
How to find the MAC address of a Linksys WRT54GS wireless router
If you have a Linksys WRT54GS wireless router and you need to find its MAC address for some reason, this article will walk you through the process of obtaining the address through the router's web interface. Other methods may be used instead -- such as Windows Vista's Network Map or a third party utility. (The MAC address is also printed on a sticker on the bottom of most routers, but if the router is hidden behind a computer desk or trapped in a tangle of wires, using the web interface will probably be easier.)
First, open a web browser window and type in your router's local IP address (typically, 192.168.1.1) and hit Enter. When prompted, type in your username and password to gain access to the router's interface.
Once you've logged in, the blue and black Linksys page will appear. Click on the Status tab (the last one on the right).
The MAC address is assigned to the network interface port inside the router, not to the actual router as a unit, so since the WRT54GS has two network interface ports (one for your local area network and one for access outside your network) it will therefore have two MAC addresses.
The MAC address for the port that connects to the wide area network or to your Internet service provider can be found under the Router heading beneath the Status tab. It will be listed below Firmware Version and Current Time, and it will appear as six pairs of letters and numbers separated by colons.
The other MAC address, the one for the local port, can be found under the Local Network heading, and it will be the first item listed there. Typically these two addresses will be very similar -- maybe separated by one or two digits.
on Sep 28, 2010 | Linksys Wireless-G WRT54GS Router...
Linksys wrt54gs changing upnp settings
Hi, you can enable UPnP on a Linksys WRT54GS router by logging in and then clicking on the Administration tab. The first sub-tab is Management, and at the bottom of that page there are buttons to enable or disable UPnP. Click Enable and then click Save Settings at the bottom of the screen.
Jul 21, 2010 | Zyxel P660HW-D1 Router
I can't get my new Nintendo Wii to access myr router
According to Nintendo web site, it happen because of firewall on the router.
You will need to disable to firewall on the router.
Open the set up page of the router. Disable the firewall. You will see it under security tab.
Reduce the MTU to 1365.
Also you can open some ports for the WII.
Click Here for more information about the routers and network
Apr 30, 2010 | Linksys Wireless-G WRT54GS Router...
My Linksys will connect with a cable but wont connect wireless!
Connect with a cable, and then follow the directions in the manual that came with the router, in order to connect to the web-server "inside" the router. Run the "Wireless Setup Wizard" to configure your wireless network.
Nov 27, 2009 | Linksys Wireless-G WRT54GS Router...
Need lynksys installation cd, do you know where I can find it?
You download the software needed to configure your Linksys wireless router from Linksys website.
If you have version 7.2 click below
http://downloads.linksysbycisco.com/downloads/WRT54G-v7.2_Setup_Wizard,0.zip
If you have version 7.0 click below
http://downloads.linksysbycisco.com/downloads/WRT54Gv7-EU_v7_00_4,0.zip
Take your pick.
Sep 22, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS
No, you should however, log into your Linksys's admin page and copy your settings down. Put those back into your Netgear and you should be good to go.
Feb 15, 2009 | Linksys Wireless-G WRT54GS Router...
Wrt54gs router for iMAC
go to page 7
Follow the step by step for using the web based interface.
Hope this helps.
Nov 30, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54gs
ya if firewall is there then remove it when you connected your net after then you give the friewall.
for the security settings you have to go for the router page and go there one option is there security enable go for it
May 21, 2008 | Linksys Wireless-G WRT54GS Router...
You just needed to Connect ur router to the computer
1>open Internet explorer type 192.168.1.1 and then Enter
2>Leave the username blank and password admin(lowercase)
3>then in linksys page change the Local IP of the router to 192.168.2.1 and then power cycle the network it will not create any problem later
Mar 08, 2008 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54GS Router (e125894) Logo
105 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
