Question about Northgate NGI Athlon XP 3200+ 400FSB Barebones Kit without Memory (ASBBNORAMNGIXP3200) Motherboard
Ram i have a ddr ram slots i was woundering if i could put ddr2 ram in without hurting my motherbourd or any other parts?
  • xwscasper Feb 14, 2008
    motherboard sry was in a rush lol
  • 37 Answers
DDR and DDR2 are both electrically, and physically incompatible, and so you cannot use DDR2 in this case.
So no, you cannot hurt your motherboard as you will not be able to fit this memory, as the 'slots', or keys, are in different places.
Posted on May 19, 2008
  • Northgate Master
  • 13,433 Answers
If you have a motherboard with only ddr1 support (speeds 266 to 400mhz) You cant put in a ddr2. It might just go BEEP BEEP BEEP BEEP or it might harm the ddr2 memory I dont know I have never put wrong memory into a motherboard. :P Good luck thought!
Posted on Feb 15, 2008
Memory upgrade 2gb 4gb
The CF29 comes in two basic flavors:
#1: With 256MB RAM and DDR Ram with One open slot.
So add a 1GB DDR RAM (PC-2700) DDR 333 and
the maximum RAM is now 1.2GB
#2: With 512MB RAM and DDR2 Ram with One open slot.
So add a 1GB DDR2 RAM (PC2-5300) and the
maximum RAM is now 1.5GB.
This is my experience and very frustrating to find out the
hard way that the CF29 does not support a 2GB DDR2
RAM Module.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Jun 05, 2013 | Panasonic Toughbook CF-29 Notebook
Can i use DDR2 SODIMM 800MHz PC6400 in my laptop even though the one in it now is a DDR SODIMM PC3200 CL3?
pc3200 is original ddr- ram but pc6400 specifies to ddr2. The ram is not compatible. And the key slots on your mainboard will prevent installation.
Aug 20, 2011 | Compaq Computers & Internet
My EPoX 4PDA5 has 2 512mb ddr ram's, I was wondering if i could replace them with 1gb ddr2 or ddr3 without changing the motherboard, or would i be able to get 2 1gb DDR's and still use the 512's? because...
From http://www.motherboard.cz/mb/epox/EP-4PDA5.htm:
4 DDR modules for DDR 333/400 dual channel architecture
If you have 4 ram slots and only 2 are filled, you just need to match the speed of the two you currently have, they can be any size(500mb, 1gb, etc). I'm not sure you'll be able to find DDR ram anymore though.. and NO you cannot use DDR2 ram.
Jan 12, 2018 | EPoX EP-4PDA5 Plus Motherboard
Can i use DDR2 RAM instead of DDR1
YES, if your motherboard accepts DDR Sdram, and DDR2 Sdram ram memory. If your motherboard has both types of ram memory slots.
BUT, you can ONLY use DDR Sdram, OR, DDR2 Sdram.
You Cannot use both types of ram memory in the motherboard, at the same time.
(BIOS will only recognize one type at a time)
NO, if your motherboard does not have ram slots for both DDR Sdram, and DDR2 Sdram ram memory.
Double Data Rate Sdram ram memory modules, have 184 gold plated contact pins on the bottom.
92 on Each side,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the above photo to enlarge)
DDR2 Sdram ram memory modules have 240 contact pins.
120 on Each side.
Sep 04, 2010 | HP Computers & Internet
Can i upgrade my ram to ddr3 if so what would you recomend .cheers
Thank you for the clarification sir.
NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
This is the support page for the Fujitsu Scalio 600 Media Center,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
Uses either DDR Sdram at 333MegaHertz, or 400MHz.
(PC2700 and PC3200 respectively)
DDR Sdram has 184 gold plated contact pins on the bottom.
DDR2 Sdram has 240 gold plated contact pins on the bottom.
DDR3 Sdram has the same amount of contact pins as DDR2.
The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
Nov 18, 2009 | Televison & Video
Two 1GB 400MHz RAM's or two 1GB 333MHz RAM's??
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot
So, yes, you can put two 400MHz modules in the slots.
Jul 05, 2009 | MSI 915GLM-V Motherboard
Asus p5 vdc-x motherboard not recognizing ddr2
Ok i am just guessing here
maybe your motherboard does not support
ddr2 rams and hence it wont boot up as it does not detect any ram in the slots......
try to boot with one old and one new ram (ddr and ddr2) and post the result
are you sure whether the ddr2 ram is supported?
Jun 30, 2009 | ASUS P5VDC-X Motherboard
Is DDR2 Compactible with gigabyte 81845ge-rz motherboard?
No. If the current RAM is DDR, then DDR2 will not work.
The slots are slightly different, and the DDR2 won't even fit into a DDR slot.
Apr 28, 2009 | Computers & Internet
Can i use DDR 2 RAM for U8668d ver. 6.1 motherboard of 1GB
your motherboard uses DDR1 SDRAM PC2100 max. as stated on their website:
http://www.biostar-usa.com/mbdetails.asp?model=u8668+d
you cannont put DDR2, but you can expand up to 2GB
Hope this helps
Alex
www.CAS411.com
Mar 17, 2009 | Biostar U8668D (802700113338) Motherboard
Can't Install RAM in DDR2 and DDR3 DIMM slots
You cannot use DDR and DDR2 ram at the same time, because its always been like that (ie, no SD and DDR, or SD and RIMM)
What you should do is switch to all DDR2 sticks.
Jan 09, 2008 | Gigabyte GA-8PE667 Ultra Motherboard
Northgate NGI Athlon XP 3200+ 400FSB Barebones Kit without Memory (ASBBNORAMNGIXP3200) Motherboard Logo
61 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Tom Chichester
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
