Question about Acer AL1716 17" LCD Monitor
Acer al1716 colour problems
As of the 13/2/08 my monitor now only displays in hues of purple/lylic and shades of green .
i have tried to change the colour settings within the monitor menu but to no effect ,have also tried to change colour settings through vista to no effect , also tried to change settings through ATI catalyse controle center ,again to no change.
i am wondering weather ther may be a fault with said monitor or a damaged cable??
system-- gateway E 4076 ,intel p4 3.00 ghz processor, ati x1650 pro graphics card pcie ,2 gig ram ,windows vista premium ..
Did anyone of u guys install a more powerful gpu on your board at anytime when that happened?? because im having the same problem...but im almost positive its because i recently upgraded from a geforce 7300 to an 8800gt oc and thats precisely when the purple hue flicker started...just a thought since like i said i have the same issue...buying a new monitor nutz to benq corp :)
Posted on Jun 27, 2008
I have an Acer AL1916 which I bought new in March 06. It became faulty when the colours changed. In addition the whole image shifted to the left a few inches (now and again). Like yourselves I thought it was the cable / PC but it was the same on a seperate unit. Concluded faulty - so back to Acer it went. They repaired it and it came back with the colours back as they should.
However, 10 months on, it's done it again. I turned it on Monday and the screens gone back to a horrible purple hue.
So back to Acer it goes again. I'm not impressed at all. Temped to fight and try and get my money back. Clearly these screens have a reoccuring fault and it sounds like you guys have the same fault.
LB
Posted on Jun 11, 2008
I have a acer al-1916 with same problem n i cahnged the cables n still getting purple colour n unfocus image.
U have any solution for that?
Posted on May 06, 2008
  • 77 Answers
Yes, I'd say your cable is faulty. If it is the type you can disconnect, then change it. If it is moulded to the monitor then you might have a problem. check all of the pins on the connector to make sure they are in tact and not bent.
Posted on Feb 20, 2008
Acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Mar 25, 2010 | Acer AL1716 17" LCD Monitor
Our acer monitor (AL1702W)displays almost all in green colour except white but white is also with greenish shade. Monitor Sr. No ETLA708029818072674211, SNID 81802928742, MY Email Id is...
Please check the connector at the end of the cable connecting your monitor to your VGA port in your computer. Check if there are any bent or broken pins, or if the cable is damaged near that connector. If this is the case, you will need to get this connector replaced to fix the problem.
Mar 22, 2010 | Acer Computers & Internet
Al1716 monitor plugged unable to change resolution.
You need to set the PC resolution to the native resolution of this ACER monitor, which is 1280x1024 @ 60Hz.
Mar 10, 2010 | Acer AL1716 F Monitor
Acer al1716 dont work
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 03, 2009 | Acer AL1716 17" LCD Monitor
Broken monitor screen, model IIM15J
it is called colour fade.it can be seen in many old and few in new crt monitor.Due to the not properly fitting inner parts of board and other. it can be repair expert technician by soilding.. it is not softwere problem..--thanks
Jun 15, 2009 | Computers & Internet
My monitor has a green hue that will not go away when I adjust the colors in the screen. The blue adjuster doesn't seem to do anything. When I use auto adjust, It looks amazing for about 5 seconds then...
If you have another PC try it on the monitor, see if the problem persist. I f it doesn't check your video card's control panel. Some configuration there, may be overriding your monitor's. If you have an nvidia based card run the "optimize my display wizard"
May 08, 2009 | AOpen F2715-8S Monitor
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
Screen ajustment
Hi stefan,
You can adjust manually using the OSD (on-screen display) menu of you monitor by pressing menu button. Other monitor OSDs cannot be accessed on single button but some combination of buttons but considering it can be accessed, please look for it. Try also changing the properties at Operating System GUID (graphics user interface display) Control Panel Display or your monitors display monitor application software. Try changing the frequencies and other special features like single screen or wide screen, etc..
Best regards,
Rosener
Jan 30, 2008 | Acer AL1716 17" LCD Monitor
Screen color is purple
if you have access to another monitor use if to verify the monitor is the problem and not the video card of the computer.
does the monitor allow you to adjust color and tint(hue) because the tint or hue control changes the overall color from green to purple. or the color control circuit has failed leaving you stuc with a purple screen.
Dec 26, 2007 | Dell E176FP 17" LCD Monitor
Acer AL1716 17" LCD Monitor Logo
489 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
