Hi, even though the freezer is working, you need to check the evaporator fan in the freezer to make sure it is running to move the air to the lower part of the box. If you open the door on freezer, make sure it doesn't have a switch around the perimeter that will shut the fan off. Some do and some will not. Check this and get back to me. You may have a faulty thermostat control. Get back to me and let me know about the fan motor. I will wait for you're response.
Shastalaker7
Hi, The thermostat I would say around $30 or so and yes this is something you can do. Just make sure you draw a diagram on the wires you remove. Get the model and serial numbers off the unit so you can get the right one. One more question, Did you check to see if the small evaporator fan was running in the back of the freezer? You can't see it but should be able to hear it running. If it is not on then the fan motor is the problem and not the control thermostat. Remember I asked you to check this motor and to make sure there was no switch around the perimeter and you say there is not? The fan should be on when the door is open.
Sincerely,
Shastalaker7
Hi, Yes, let me know if the fan runs at all this is important. And if isnot running you can also remove this you're self to replace. Make sure you kill the power first! Remove any plastic covers to excess it. Should have only 3 wires, 2 Black and 1 Ground, or 1 blk, and 1 wht, and ground.
Shastalaker7
Hi, thank you for the awesome rating, this was very kind of you. I still haven't heard back from you on the comments I have posted? I hope it is working ok at this time, or you were able to find that the evaporator fan was bad and you replaced it. Please let me know where you stand at this time.
Sincerely,
Shastalaker7
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check
Refrigerator
not Cooling
Timer Problem
Water
from Freezer
Refrigerator
heatman101
heatman101
Thank you for the quick response.
I have checked the perimeter of the freezer and have no switch.
In the meantime I have fully defrosted the freezer and today again freezer is fine but fridge is still not working.
Hope this helps?
How much would I have to pay for a new thermostat and could I fit it myself?
Many thanks
Hope this helps?
Many thanks
