When I press print the letters AP apears and
The final copy is just a plain blank paper, I just replaced the tonner.
  • 168 Answers
What is the Brand/make and model number of your copier?
Posted on Feb 15, 2008
4 wide horizontal blurry lines in printed document
Either sensitive drum of the tonner is damaged or the high temperature fuser roller damaged. Check and replace.
Nov 17, 2015 | Brother DCP-7020 Laser Multifunction...
Blank page when I copy or print reports
Re check all the connections. When taking off the paper feed assay, other parts and plug and jack connections were needed to be taken off first.
Make sure the drum seats in its correct position, silver grounds are not bent.
The copy cartridge and Dev housing are not connecting very good somewhere.
Make sure the machine is unplugged.
Try running copies.
Apr 21, 2010 | Xerox WorkCentre Pro 580 Plain Paper Laser...
Replaced the power supply/controller pca on a ricoh 2210l. prints fine, but copies come out black. adjust shading procedure yields copy with vertical black stripes and sometimes a faint negative image of...
If the tonner has gone old please take it out and shake if for atleast 2 to 3 minutes before putting it back and takng printouts. The issue would resolve but its a temporariy fix as you would require to change the tonner .
Let us know if you need further clarification.
Thanks
Dec 30, 2009 | Ricoh FAX2210L Plain Paper Laser
My printer will not print any documents, it does print a test page, when I select print the paper is ejected. I have re installed the software.
Try to print a self test page from the printer directly using the below steps....
  1. Make sure the printer is loaded with plain, white paper. Remove any special or colored paper.
  2. Press Setup on the front panel of the product.
  3. Press 1 , to select Print Report , then 5 , to select Self Test .After you have the report printed, check for 4 horizontal color bars in that report, the first color should be the the black one, if the black one is missing, issue seems to be with black cartridge, that may be the reason the printer spits out blank paper, try to replace the black cartridge and then copy if it copies or not.
Sep 26, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer message apears "change tray 1 plain letter" when i press print. will not print until i press select. Ive tried changing printer setting and cant seem to fix it..
change the paper type at the printer to plain letter, or in printer properties from the start menu.
-Carl, please let me know if this helps.
Jun 25, 2009 | Office Equipment & Supplies
Blank print top 1 inch has print Toner cartidge has been changed
I need more information. If you make 20 copies do you still notice the problem or only when you receive a fax. What is your copy count (press life 1). Does it jam or make noises. At first glance I would say phone line problem. .
May 26, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
k24674
jasbo
jasbo
Marvin
Marvin
