Question about Canon BJ-W9000 Copier
Installed new ink tank not detecting ink
Describe your problem
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Go to this site and look at " save my inkjet"
http://checkitright.spruz.net//main.asp?page=dp&dis=592197
then go to "keep your head clean"
Posted on Feb 15, 2008
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
Tip
Duplicate Cartridge Error - Which one is causing it
The purpose of this exercise is to rule out ink tanks that are behaving and isolate the one(s) responsible for the duplicate. Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
Hope this helps
Mike
on Aug 04, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon W8400 E02804
Check x Tank (the ink color is indicated by x)
This is displayed when an incorrect ink tank is installed.
The final digit indicates the ink color.
So you have problem with Bk ink tank...
This is displayed when installation of an incorrect ink tank is detected.
This is displayed when a checksum error occurs in the ink tank EEPROM.
Ink tank, ink tank unit, engine controller, system controller
1. Replace the ink tank.
2. Replace the ink tank unit.
3. Cable connection check
Replace the cable between the ink tank unit and engine controller if the connection is not functioning normally.
4. Replace the engine controller.
5. Replace the system control
So as you can see there is a lot of possibillities, ... call service
Aug 08, 2011 | Canon imagePROGRAF W6400 InkJet Printer
Canon mp830 service error 5c310 alarm light keeps
http://damnprinter.com/226/canon-service-call-errors.html
http://www.fixyourownprinter.com/forums/inkjet/26091
You need to clean your waste ink i think. For troubleshooting purposes, please perform the following:
May 17, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I have a message showing bk tank - code
Its detecting an incorrect ink tank.
The printer is not happy with one of your tanks. Make sure you have PB inks if it is a PG printer.
More probably the job you are printing requires the other black ink tank. Very important to make sure your status monitor is installed correctly, make sure when you send a job that it displays the ink tank levels and not question marks. You should be able to find out roughly how much ink is left through the driver (status monitor) and also what type of black is installed. If you cant, you have not got the 'Status Monitor' installed.
Mar 09, 2010 | Canon imagePROGRAF W6400 InkJet Printer
UO43 error there is no ink cartridge there, but when there is an ink catridge UO71 it says more than one ink cartridge
Hi there
Perform the following:
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 08, 2010 | Canon Pixma MP500 All-In-One InkJet...
ERR0R U071 MORE THAN 1 INK TANK OF THE FOLLOWING COLOUR IS INSTALLED. (CANNON PIXMA MP500)
Hi there
Feb 10, 2010 | Canon Pixma MP500 All-In-One InkJet...
Showing Check Ink U051 COL. Have removed the
Hi there
Feb 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Error 252* - What is this error?
An ink tank which has once been empty is
installed. Replace the applicable ink tank with
a new one.
Printing with a once-empty or refilled ink
tank can damage the print head.
If printing is continued without replacing the
refilled ink tank, press the Stop/Reset button
for 5 sec. or longer to record the use of a
refilled ink tank.
Note:
After the above operation, the function to
detect the remaining ink amount is disabled.
Oct 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Refilling Ink in Canon Pixma MP830
Hello, I found this in a repair manual for the MP830. summery is to press and hold the stop/reset button for 5 or more seconds. I copied the info from the manual too. The remaining ink amount unknown. [1683] (Applicable ink tank icon) The remaining level of the following ink cannot be correctly detected. An ink tank which has once been empty is installed. Replace the applicable ink tank with a new one. Printing with a once-empty or refilled ink tank can damage the print head. If printing is continued without replacing the refilled ink tank, press the Stop/Reset button for 5 sec. or longer to record the use of a refilled ink tank. Note: After the above operation, the function to detect the remaining ink amount is disabled.
Jul 17, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon BJ-W9000 Copier Logo
63 people viewed this question
old marine
old marine
