Question about Microsoft Xbox 360 Console
Xbox 360 hard drive
Had a red light flashing and it meant hard drive problem i bought a new hard drive and it works but dont know about everything bi have saved and do i have to re register on live and what about my live membership
    Problem Solver:
  • 13 Answers
Dude thats the three rings of death thats why i got a ps3
Posted on Jun 26, 2009
  • 54 Answers
I wouldn't think you would have to re-register if your profile account is still saved. your membership as well. just give it a try and see. good luck : )
Posted on Feb 15, 2008
My xbox 360 is now showing flashing 1 red light on and off
These steps are taken from the support site as always, it's the first website where you should look.
Solution 1: Disconnect and reconnect cables
Here's how:
  1. Turn off your Xbox 360 console.
  2. Unplug all memory units, controllers, and accessories from your console.
  3. Unplug everything from the back of your console, including power and video cables.
    Don't remove the hard drive.
  1. Reconnect your console's power supply.
  2. Reconnect each accessory one at a time, starting with a controller.
  3. After you've reconnected every accessory, turn the console on.
Solution 2: Remove the hard drive
To see whether the problem involves the original Xbox 360 Hard Drive, temporarily remove the hard disk drive. Here's how.
Note Not all Xbox 360 consoles include a hard drive. If your Xbox 360 console doesn't have a hard drive, to go Solution 3.
  1. Turn off the console.
  2. Locate the hard drive on the top of the console (or on the left side, depending on how the console is oriented).
  • Press the release button on the hard drive.
  • Lift the hard drive away from the console.
hdseparating.jpg If these steps resolve the issue, reattach the hard drive to verify that the error occurs only when your Xbox 360 Hard Drive is connected.
Solution 3: Disconnect memory units or USB flash drives
Here's how:
  2. Unplug any memory units or USB flash drives attached to your console.
  3. Turn on the console.
If these steps resolve the problem, reattach the memory unit or USB flash drive to make sure the error occurs only when it's connected. If this is true, order a replacement memory unit or use another USB flash drive.
Solution 4: Request a repair
If the previous steps don't resolve the single flashing red light issue, there are no additional troubleshooting steps. Your original Xbox 360 console must be repaired at our service center. Start the repair process online.
Jan 09, 2015 | Microsoft Xbox 360 Console
Xbox 360 3 flashing red lights
Well if they're flashing the hard drive is over heating and you need to get either a new hard drive or a new Xbox.
Feb 11, 2014 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
MY XBOX 360 HAS 1 RED LIGHT FLASHING, WHEN STOOD ON ITS SIDE THE LIGHT IS BOTTOM RIGHT
one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables. first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more. If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you. The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Jun 06, 2009 | Microsoft Xbox 360 Console
The video dont work and error 86 comes up on the screen
The E86 error code is a hard drive error, remove your harddrive and try powering up. If it works without it, try reformating the xbox 360 harddrive.
THIS WILL DELETE EVERYTHING:
Settings > System Info and press Y, Up (left stick), Down (left stick), X, A.
If that does not work you may need to purchase a new harddrive, you can get them online, or in most stores.
May 24, 2009 | Microsoft Xbox 360 Pro System Console
My xbox 360 has the third player light flashing red.
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
You should still be under warranty, follow the above url, and get a repair request in, it should be no charge.
Dec 27, 2008 | Microsoft Xbox 360 Console
Xbox 360 elite 1 red light
The number for Microsoft is usually listed on the back of any game manual.
I hope I was able to fixya problem, and Happy Gaming!
Oct 18, 2008 | Microsoft Xbox 360 Elite Console
Xbox 3 red lights problem help please
3 red lights normally means there is a general hardware failure.
Are the lights flashing?
Turn off the xbox and...
Try unplugging everything from your xbox, plug it back in and turn it on.
if that doesnt work, when your xbox is turned off, take the hard drive out and restart your xbox. If it works with the hard drive, try restarting it again after putting the hard drive back in.
Apr 10, 2008 | Microsoft Xbox 360 Console
3 red rings flashing on xbox 360
hey man, i dont own a 360, but i know that red rings are know as the red rings of death on a 360
Mar 17, 2008 | Nintendo Game Boy Advance Console
Xbox360 3 flashing red lights
Google up the red ring of death. Its a common over-heating problem on Xbox 360s. There are various solutions to this problem. The most recommended one is to take your console to Microsoft to get it checked. If you dont have an xbox 360 representative in your country as is my case, the second best solution is to buy a new 360 which comes more "prepared" for this issue. If you dont feel like spending 400 dolars on a newer model of the 360 then you should try some of the alternative temporary fixes. Most fixes have been reported as temporary, although if you are lucky maybe your Xbox 360 will last a long time fixed.
Basically solutions require to void your guarantee. Any fix which requires you to open your Xbox (the thermal-paste and the rubber fixes, etc (i will post link at end of comment)) will automatically void the guarantee. Theres a temporary solution which almost always works which is to wrap your xbox into towels without the hard drive and cables, only the power cable pluged in, and the console turned on. It will heat up and after 10 or 15 minutes unwrap it, let it cool down and you'll be playing in no time. Although this is definitely not recommended as you will be over-heating lots of components which are working well and could damage them. Well, hope this link works and saves you money. http://www.fixya.com/support/t142158-3_flashing_red_lights
Nov 03, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
