Question about Samsung DVD-909 DVD Player
Image "cut" DVD played through AV1 on ORION TV32RN10D (Scart connection) produces an image that seems to be misplaced : wider black band on the top, image cut at its bottom. Thanx 4 help
You search and search and search, and in the end you solve the problem, you don't even know how ?!?
Posted on Feb 15, 2008
Transfer to DVD?
If the mini has two scart sockets you can connect a scart lead from scart 2 or av2 into av1 on a dvd recorder then select av1 as the record channel on the dvd and the press play on the mini and record on the dvd.
Mar 13, 2014 | Panasonic AG-DV2000 Mini DV VCR
I have Toshiba DVD player/recorder DVR19DTKB2 Problem with timed recording which up to now has worked OK ! I can see the unit recording but when I check the finished result the image is blacked out ie no...
I had a similar problem- check your scart lead is connected firmly.
Also check which socket it is in - not handy if it is in socket 2
and you are recording on AV1.
Hope this is helpful
Pete
Feb 21, 2010 | Televison & Video
I want to hook up my dvd to the tv, but I dont know what plugs into what
check for any HDMI Input on Tv, and also on DVD as Output , or connect a SCART CABLE from DVD SCART(TV OUT) to TV SCART(AV1 or 2), note:
Use a High quality cables, better IMAGE/AUDIO is achived.
Jan 10, 2010 | Televison & Video
I have a new samsung blu-ray player... but manual does not list remote code to make the new remote compatible with my Sylvania TV... any ideas??
try connect to the tv AV1/2 scart connector, with a full scart cable (top quatily),and use tv AV1/2 cannel to test
Jan 02, 2010 | Samsung BD-P1590 Blu-Ray Player
Where to put scart leads into dvd and video player and panosonic tv
Look at the rear of the TV/VCR/DVD & you will see long black sockets where the Scart cable is connected onto, these are normally indicated as AV1/2 etc. You can then take Scart from DVD to TV on AV1. Then on AV2 take the second scart from VCR to TV or you can take the second scart from the DVD to the VCR & from the VCR to AV2 on the TV.
Nov 29, 2009 | Panasonic CT-32SL14 32" TV
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
Oct 30, 2009 | Televison & Video
How do I connect my dvd player with a virgin box do I need 2 scarts in my tv?
Your virgin box should have two scart sockets,if you only have one scart socket on the tv then...Put a scart lead in the one marked tv on the box and plug it into the tv,then from av1 on your dvd take a scart and plug into the other socket on the box.If you cannot get the dvd to play when the box is on then switch the box off.
Oct 27, 2009 | Televison & Video
I just bought a second hand sumsung tv with a vrc attached. it has A/V connections but for some reason i cant hook it up to my dvd player...not sure WHY!?
connect up your scart lead, from the scart socket on dvd player to the scart socket on tvyer. There are usually to sockets to connect to on the tv, it will be AV1 or AV2. To view dvd, press source button on tv remote to select AV channel you have connected the dvd played to.
Aug 15, 2009 | Samsung Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Dvd video player model no DVP3120 unable to get player to play on tv setting AV1 at all but on tv setting AV2 player plays dvd`s but picture only no sound. it is connected using a Scart lead.
through a process of elimimation I identified the problem as a faulty scart lead
replaced lead and all was okey dokey
thanks for advice posted
colin the cat
Jan 22, 2008 | Televison & Video
Samsung DVD-909 DVD Player Logo
47 people viewed this question
Jerry Greenberg
Jerry Greenberg
