Question about Bose Wave Radio
Cd player not working
Hi i have a dual cd player, it was working fine but when i took out the cd and put another one it just started ticking and did not read it, i tried it with multiple cds but with the same problem and some times the cd doen't go it all the way. do u have any idea on what's wrong with it??
thank you
There may be a small obstruction inside or underneath the cd tray preventing it from closing all the way.[a piece of something may have broken inside] this may sound stupid, but you can try shaking the unit and listening for something loose or rattelling, and try to have it fall out while the cd tray is open. [i recently had this problem] check also for the cd tray to align properly when closing into it's opening.
hope this helps.
wg
Posted on Feb 15, 2008
Right hand deck makes ticking sound & will not read cd
The laser pickup is shot, the whole assembly will need to be replaced in order to get it up and running properly.
Apr 23, 2012 | Nu Mark Numark Cd-Mix-2 Dual CD...
My american audio radius 3000 shows error
see if you have a reset button on the radio my kenwood was doing that its a tiny hole on the front you need a pin to reset it its that small and it works fine now
Mar 04, 2012 | American Audio Dcdpro610 Dual CD Player CD...
IT POWERS UP FINE BUT IT DOESNT SEEM TO BE READING THE CD'S I PUT IN EVEN ONES IT HAS READ IN THE PAST.
the lens cud be dirty or damaged or the cd spindle motor has gone bad. in case of dirty lens try using lens cleaner cd. that dont work means probably spindle motor is out.
Mar 12, 2010 | Nu Mark Numark Cdn36 Dual CD Player CD...
Cd/Rw playback CD player in lounge room won't play burned cd's...
Hi.
You need to burn your CDs in Audio format. That means that you cannot just burn your MP3 or WMA files, but you need to use the program which can convert those files to WAV format and write them so that ordinary CD players can reproduce them. Nero is such a program, among others.
Your responses are intended to improve the level of service provided. Please rate your experience.
Jan 17, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Dual xdvd8181
i have a dual xdvd8181 cd player and the radio works fine but it will not accept a cd. what do i need to do about solving the problem?
Jul 22, 2008 | Car Audio & Video
Cd stuck in my Dual XD5120 cd player in my car.
if the cd player has failed about the only way to retrieve the disc is to take apart the player
Jun 20, 2008 | Car Audio & Video
Cd player problems
I installed a dual xdm7510 reciver in my car and it worked fine for a day but now it will not play anything. Sometimes it will play and sometimes it will just eject any cd that I put in it. write me at jefferysprouse@yahoo.com
Sep 07, 2007 | Alpine CDA-7995 CD Player
NO Power
Hi. You need to check a few things. make sure you have power on both the red and yellow wire with the key one. If only one has power the radio will not work. also make sure that you have a good ground connection on the black wire.. if nothing works yes you probhably have a bad radio. the dual brand radios are notorious for poor solder connections on the mainboard due to the way they build thier cheap circuit boards..
Sep 03, 2007 | Dual XD-7500 CD Player
CD PLayer won't play CD's
Hi First of all, you must find all the screws for the top cover and remove it. Make sure the unit is not plugged in! Then, making sure that you are not touching anything inside the unit, plug it back in,put a Cd in the drawer, and watch what happens. If the drawer closes, but you can still hear a motor running, then it is a belt drive unit, and the belt is slipping, if that part is ok, listen carefully for a ticking noise, which is the laser lense going up and down trying to focus on the CD, if the disk starts to spin then the mech has closed properly, and the unit is trying to find the directory. If the unit then spins the disk for a while then ejects it, then the laser is dirty or faulty. I would suggest getting it cleaned at a shop if the lense appears dirty. ***Never look straight down at the laser lense if it is exposed on your model of CD player, it is a class 3 laser, and you will be doing some harmful home laser surgery to yourself!!!*** Hope this helps! Good Luck! P.S. When following the steps above, if you hear the ticking of the lense moving up and down, but the disk does not spin, gently spin it clockwise with your finger, if it starts to play, or finds the directory, then the spin motor is bad.
Aug 13, 2006 | NAD L40 CD Player
Bose Wave Radio Logo
170 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
