Question about LG VX9800 Cellular Phone
Cant format SIM card
Try to format and it says "format failed" Using a 256mb card. Tried 2 others, get same error.. Any ideas?
  • andyhayden Feb 24, 2009
    Bought two 2gig mini sd cards but neither one will format
    Novelist:
  • 141 Answers
Using the miniSD Card
The V can access the following file types stored on the
removable miniSD card:
My PIX: gif, png, jpg, bmp
My Sounds: qcp, mid
My FLIX: 3gp, 3g2
My Music: wma
You do not need to format the card, just put it in the slot. The phone will do the rest.
You can chek the card by going to settings and tools---scroll down to memory--ok--go to card memory--ok---and it will show you the information about the card.
http://www.cellphones.ca/upload/manuals/lg-vx9800-manual.pdf
The link above is the manual for your phone.
If you are trying to copy pics and musics to your SD card or phone and cannot, let me know and I will tell you the easiest way to.
Posted on Mar 27, 2008
RAGISTRATION FAILED
Have you tried with another Sim Card? If not do so now. In case sim card is not the problem then this must be 1. sim ic (sim controller) problem, if you don't have idea, better go to a repairing shop to get it done, otherwise you might create another damage. 2. Firmware problem. You'll need to flash your mobile if this is the culprit.
Good luck. Thanks for using Fixya.
Jun 01, 2010 | Nokia 1600 Cellular Phone
"Storage Device Unreadable. Format Now.?"
yes there is a possible solution to your problem....there seems to be a problem with your card....and it doesn`t look like you can get your data back from it ...so you will have to format your memory card....connect your card to a computer through a memory card reader by also using your micro card`s adaptor and then format it from your computer......hope this helps.....please vote ...help us to help you better
Aug 07, 2009 | Motorola Mobility V360 Cellular Phone
A 2gb memory card says memory full tried it in
No, that camera works with the 2gb cards just fine. You will want to try to format the card in your computer first, then try it in your camera (format it in the camera before using). If it doesn't format in the computer, it is a bad card.
Jul 19, 2009 | Kodak EasyShare C330 Digital Camera
Memory card
hi
try formating once. may be the card is okay but formated in diffeent format.
also, try using on other camera or pc to find is it working
Apr 01, 2008 | Electronics - Others
Error 30
The "E30" error code indicates reading/writing data on a SD card has failed. Especially, the error code "E30" may appears when you tried to remove a SD card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another SD card. If you have another SD card, try loading it in the camera. If the error code is not displayed when the other SD card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the SD card for errors. Use ScanDisk to check the SD card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the SD card on the computer before you check the SD card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the SD card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the SD card with your camera Try to format the SD card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting SD cards. Also, please note that formatting a SD card will erase all data on the card. Once the SD card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the SD card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the SD card.
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD200 / IXUS 30 Digital...
Error 30
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Error 30
Aug 29, 2005 | Canon PowerShot SD10 / IXUS I Digital...
Error 30
The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
LG VX9800 Cellular Phone Logo
1,104 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
