Question about Alpine CDA-7998 CD Player
Alpine Compact Disc Changer 7982
The information on the Alpine radio states:
Alpine 3D shutter 3D control
Need instruction booklet
Can you help?
  • Collegeboy Mar 31, 2008
    Hey, need some help here. I have an old school Alpine 3342 BBE digital EQ, and a Alpine 7982, in dash 3 disc changer.
    I know it's old, but I love the setup and it sounds great. The problem is with the 7982 3 disc unit... See pic for reference.
    [imghttp://i236.photobucket.com/albums/ff214...[/img]
    Recently the digital display for the detachable faceplate will not light up. I have a 2nd unit of the same radio that I boiught a few years ago, just in case my orignal one ever broke. Now, here's the thing, the faceplate lights up and works fine on the 2nd unit, so this leads me to believe there is something internal in the 1st unit that isn't sending the illumination to the faceplate. All the buttons work, etc, but the display won't light up.
    Is there anything I can swap from the inside of the working unit, into the other? Maybe there is a certain circuit board I can swap from one to the other? I"ve had the unit apart in the past to remove a jammed cd, so I'm pretty good. I can't use the 2nd unit because the tuner doesn't work.
    Any ideas? I don't want to replace it with a newer style, as both the EQ and the radio match.
    Thanks.
    Thanks.
  • 111 Answers
Go to pacparts.com
Posted on Feb 15, 2008
HOW TO PLAY COMPACT DISC WHEN COMPACT DISC PLAYER IS ON?
You press the play button......
If you have multiple disks, press the appropriate disk and it will play
How to Use Six CD Changer
6 Disc CD Changer Instructions eHow
Feb 10, 2016 | Panasonic Technics 5 Disc Compact Disc...
What is the security code for an Alpine 7982 in dash cd changer?
It wouldn't make sense to have only a single security code for every unit of that model, it will be tied to the serial number of the unit and only Alpine will have it. You'll have to contact them and you may have to somehow prove ownership since the code makes it unattractive for thieves to steal them.
Apr 20, 2011 | Car Audio & Video
Alpine CHM-S620 6 Disc CD Changer Components
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
Apr 01, 2010 | Alpine CHM-S630 6-Disc CD Changer
Can a CHM-S601 hook up to a 1997 ford F-150?
It won't work if the radio doesn't have a cd changer input. The radio/receiver has to have been designed/programmed to interface with the changer since that is what the changer is controlled through.
Jan 08, 2010 | Alpine CHM-S630 6-Disc CD Changer
Manual retrieval of a CD from an Alpine S620 CD Changer
Sorry but no. With the units power lead fused, you can hold the red wire to the + terminal of the battery and the black lead to the chassis of the car and power up and eject. good luck
Jul 03, 2009 | Alpine CHM-S620 6-Disc CD Changer
Quiet cds
you put cd wrong side .
Jun 15, 2009 | Alpine CHA-S624 6-Disc CD Changer
Which radio for land rover
Usually an Alpine unit.  Try ebay.
Mar 24, 2009 | Alpine CHM-S620 6-Disc CD Changer
CD changer will not mix discs randomly
RANDOM PLAY SHUFFLE M.I.X (has a little folder next to the mix sign. (#5 button) NOT #6
SHUFFLES ALBLUMS AND SONGS
This option randomly shuffles the next disc and songs
More info here if you need it:
http://www.retrevo.com/support/Alpine-CDA-9856-Receivers-manual/id/1060dj492/t/2/
Sep 03, 2008 | Alpine CDA-9856 CD Player
Blocked/locked alpine in dash receiver model 7982
You need to leave you radio with pwr on for about 60 to 90 minutes,then the display will show CODE and you can try again,if you don't have the right code or nobody hasn't programmed any code try this number which is a master code for this model code 0100
good luck
Jan 31, 2008 | Car Audio & Video
Alpine and gamma in vw
YOU WILL NEED AN INTERFACE TO CONNECT THESE UNITS WHICH YOU SHOULD BE ABLE TO PURCHASE FROM YOUR CAR AUDIO RETAILER OR SEARCH THE NET
Dec 03, 2007 | Alpine CHM-S620 6-Disc CD Changer
Alpine CDA-7998 CD Player Logo
300 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
