Question about Baby Gear
2002 Cadillac Escalade
Heated seat will not shut off. Runs down battery. Unplugged it but now seat is no longer adjustable as the same electrical connection runs that system. Dealership said due to Autostart. Autostart taken completely out and it still did it. Had another electrical guy replace the actual seat heater and it worked for awhile. Today (at -11 degrees) when I got into the car it turned over slowly and the seat was warm. I had not even turned the seat on. Any ideas?
  • clbp Feb 19, 2008
    Thanks for your help. I just took it into the dealership today and reported the relay advice as it was over my head to deal with. I hope that it will be a simple fix.
    Thanks for your advice.
  • 50 Answers
Might have a stuck relay you could just pull it out and see if the heater turns off its on a diffarant line it the adjuster so the adjustment still works
Posted on Feb 15, 2008
The front seats for our 2003 Escalade will not move forward or backward and the heat control for the front seats will not work.
Does your Escalade have memory seats ?
There are 2 options of power seat systems available in full size trucks. The 6 way driver and passenger power seats, and 8 way driver and passenger power seats with driver memory. For the driver memory seat operation refer to Memory Seats Description and Operation . Power seats without memory are completely controlled through the power seat switch. Battery voltage is supplied to the power seat switch through the power seat circuit breaker. While the seat adjuster switches are in an inactive state the switch contacts are closed to the power seat switch ground circuit. When a power seat switch is pressed to an active state the switch contact is closed to the battery voltage supply circuit. Each seat adjuster motor is controlled by the power seat switch through 2 motor control circuits. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Jan 16, 2017 | 2003 Cadillac Escalade
Power seats wont work, and fuse is very hot
ck for a pinchched wire under the seat
Jun 17, 2012 | 2002 Cadillac Escalade
My 2003 cadillac escalade ext stalled yesterday & wont start. If it does start up it just runs for a second & shuts off. It has power & is deffinately not the battery. It turns over & seems...
This sounds to me like the antitheft security system. If the computer doesn't read the transponder frequency coming from the key, it goes into anti theft and shuts down the starter and/or the injectors. If it starts for 1 to 5 seconds and then shuts down, its probably this. Read up about this on this link, it gives you symptoms and causes, plus a "do it yourself" solution if you decide that this is the problem. I've been dealing in GM vats-passlock-passkey securities for quite a while now. From your description, I'd guess this is the issue. http://vatspasslockpasskeysecurityhelp.yolasite.com/
May 11, 2011 | 2002 Cadillac Escalade Ext
2004 escalade drivers heated
Your switch is bad, cronic problem I've read about on the multiple Cadillac forums. Good news it is an easy do it yourselfer from what I hear.
Mar 17, 2009 | 2004 Cadillac Escalade
Cadillac Escalade Electrical Problem, Heated Seats, Power Mirrors
Dumb question, are you sure you are using the driver one remote? Being a car dealer, some installers will power the unit to certain fuses and some times this can cause issues. He may have told you 30 but most of these guys really don;t know and they are taught once and never really know if it is a problem from car to car. It sounds like a power failure of some sort causing it to reprogram itself to original specs. I went to a NTB for a battery change and I too had some issues and to my luck the guy was a GM tech at one point. So he was able to give me a few tips. Now you may not have this luck but Maybe call a few local shops like this and ask them if the have any GM techs you can run and issue by. You would be suprised where some of these guys have come from. Especially with the layoffs and need to work, anywhere....
Hoepfully this helps.
Jen
Feb 03, 2009 | 2004 Cadillac Escalade
Baby Gear Logo
78 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Marvin
Marvin
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
