Question about Sharp Viewcam VL-Z3U Mini DV Digital Camcorder
Cameras help!! my Sharp VL-Z3 mini DV camera is complaining of an " eject the casette" error or if not it is complaining of an error code of "E026". Can anyone help me?? please?? im going on a trip in 3 days and i need the camera!!!
I took mine to an authorised repair center,but was of no help. The error generally shows due to IC problem OR the head has some issue. Do not try any DIY.
Posted on Aug 26, 2008
Inserted a cassette, get the message "cannot record cassette" "protect tab". A little grey piece (probably the protect tab) fell out the camera when I set it down. Not sure where this...
On the mini-DV tapes I have, the protect tab is a slider- it does not come out of the cassette. If you look at the back edge of the tape, where the long label goes, the protect tab is at the right hand end. When it is set to prevent recording it will look like a little square hole, but there should be a tiny edge of the tab showing (mine is green) which you can pull across with a fingernail or sharp object to cover the hole and allow recording.
Nov 29, 2010 | Sharp Viewcam VL-Z3U Mini DV Digital...
Sharp video camera VL-AH50
Did you try cleaning the tape head?
Feb 22, 2008 | Sharp Viewcam VL-NZ50U Mini DV Digital...
My Sharp VL-Z3U show a message that says,:Unit In Safe guard Mode
I was able to reset camcorder and problem cleared up. Thanks.
Nov 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Replacement charger for Sharp Viewcam VL-Z3
As long as you can obtain a charger that is rated the same as the one for your camera it will not be a problem unless the original charger is a microprocessor controlled charger that has the ability to control and change the charging current as the battery charges.
A camera shop can check this out for you.
If it just a simple AC or DC charger, then you can simply use the connector from your original charger and join it either by soldering or with a screw terminal block(which you wrap in Insulating tape once fitted).
The main thing you need to be CERTAIN of is as to whether the original charger is an AC or a DC type.
This will be clearly indicated on the label on the charger.
Oct 25, 2009 | Sharp VL-Z5 Mini DV Digital Camcorder
Need manual for Sharp Viewcam Z, Vl-Z3
what causes to not be able to tor on my viewcam
Sep 20, 2009 | Sharp Viewcam VL-Z3H Mini DV Digital...
Dew and casette eject
With the dew indication, the tape will not load. This is to prevent the tape from getting stuck inside the unit. If "drying out" the unit has had no effect, either the sensor itself is bad or the connections to it are defective. Opening these is no simple task for the novice. Bring it in for service. It should not be more than about $100 to fix this problem.
Dan
Apr 09, 2008 | Sharp Viewcam VL-Z1 Mini DV Digital...
Canon ZR-800 Mini DV Camcorder tape stuck
happened to me too.. only with a sharp vl z3. It happened to me because it was filming while the battery ran out so the film is still in the camera!!! noooo!!! dang it!
Nov 20, 2007 | Video Cameras
Sharp camcorder vl-wd450
something is wrong with the m-chassis needs repair sorry the chassis on any cameras are very sensitive and they break alot not yor fault.
Nov 13, 2007 | Sharp VL-WD450U Mini DV Digital Camcorder
VL NZ50U
hello i have a probleme like you with my VL DP3S
First you must cleaner the head with a cassette cleaner 5 sec max. if it's not ok you must consulting a specialist
Oct 22, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-Z3U Mini DV Digital Camcorder Logo
200 people viewed this question
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
