Question about GE Monogram ZEU36 Electric Cooktop
'what is the amperage rating for model zeu36rbf2bb' i NEED TO ATTACH IT TO THE PROPER CIRCUIT BREAKERS
    President:
  • 1,314 Answers
30-40 amps should do it
Posted on Feb 14, 2008
Fef379ach cooktop works oven does not
They are SEPERATE. Oven controls are on a separate circuit. Look for a short, disconnect of one or more connections, or if fused, check for continuity. Check you home fuse box and make certain both circuit breakers are closed. This is a 220VAC system.
Mar 17, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
Burn knobs and fan turn on, lights are on but the burners don't come on and there is no heat.
hello after looking at your wiring diagram the only thing it can be is a blown breaker in your home. half of it works off 120v of the 240v circuit and the heating elements off the other 120v line. so you are only getting half the power to your unit. turn the breakers off and on see if maybe it just tripped.but its not the cooktop. hope this helps please dont forget to rate me thanks ken
Jun 06, 2011 | Jenn-Air JED8430 Electric Cooktop
Will not ignite. I have reset circuit breakers. what else to do?
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 18, 2010 | GE 30 in. JGP336 Gas Cooktop
Electrolux induction cooktop shuts off and won't turn back on
There is an internal thermal circuit breaker. The breaker has gone bad. On-line of Electrolux find a service manual of your model to locate the breakers location. Contact a local appliance parts store for a replacement also ask for heat sink gel(very small amount). Trip the circuit breaker, remove bad one, clean the space, apply gel and replace it.
May 13, 2010 | Cooktops
How many amps is the electric cooktop
The usual amperage rating for a cook top is 30 amps. There should be a manufacturers label that states the amperage of the unit. It may be on the back or on the edge of the unit.
Jan 05, 2010 | Maytag 30 in. CSE9000 Electric Cooktop
On-site breaker panel routing
white and ground are grounds there should be a ground rial in the fuse box, stove is 220 black and red go to 2 seperate breakers, 25 amps, and 15 amp is for 110 regular outlet
Oct 08, 2009 | GE Cooktops
Cooktop worked fine until a power outage last night. Can't get the cooktop to work since power restored.
chk for the circuit breakers.they could have triped.reset them again and try.
Aug 11, 2009 | Cooktops
No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
May 13, 2009 | Jenn-Air JGC8430 Gas Cooktop
Can fuse be blown?
youl have to pukk out the unit and check the connection/installaiton. youll need to determine if you have proper voltage going to machine. ther if no fuse on the machine, more than like a power supply issue
Oct 30, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
GAs burner igniter
This is definitely an electrical problem. Check the circuit breaker on the wall plate (where the cooktop is plugged in) as well as at the fuse box. If that is not the problem, you may need an electrician.
Feb 19, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
GE Monogram ZEU36 Electric Cooktop Logo
111 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
