Question about HP Compaq 1701 17" Flat Panel LCD Monitor
Compaq 1701 flat panel monitor
Monitor will not come on. NO power. Switched cords ... No help. Any Suggestions?
  • 472 Answers
You have a bad set of capacitors on the power board. If you have little to no electrical knowledge then I can't advise strongly enough to take it to your local TV repair shop.
The repair is not expensive and will save your life and your sanity.
Hope it helps =)
Posted on Apr 09, 2008
I am using a compaq 1701 flat panel monitor. I installed windows Xp. The screen resolution is $4 bit color coz the driver is not installed. Looking for the driver for compaq 1701 flat panel monitor for...
The screen resolution and bit color is controlled by the video driver NOT by a driver for the monitor.
Install the correct video driver for your video card and you will be able to increase the screen resolution to over 1024 X 768 and bit color to at least 32 bits.
Jul 21, 2011 | HP Compaq 1701 17" Flat Panel LCD Monitor
My monitor boots up with a white screen only
Could be video card, cable or malfunction in the monitor, try another monitor to eliminate at least the possibility of it being a graphics card issue, thereafter, check connections from the computer to the monitor, if that fails, I'd suggest taking to a TV repairman
Dec 28, 2010 | HP Compaq 1701 17" Flat Panel LCD Monitor
Does this monitor have integrated speakers?
No HP Compaq 1701 17in. Flat Panel LCD dont have inbuilt speakers.Click here to see the specification.
If you like the post then please leave your comments and feedbacks
Thanks In Advance.
Oct 05, 2010 | HP Compaq 1701 17" Flat Panel LCD Monitor
TFT8000 18.1 in. Flat Panel LCD Monitor: Was given the monitor with only a video cord. Pow...
It may have failed Backlight inverter circuits. You just need power AC cord and the VGA cable to attach to the PC VIDEO card. Try it on another PC.
http://s807.photobucket.com/home/budm/allalbums
May 17, 2010 | Compaq TFT8000 18.1" Flat Panel LCD...
Hi, I have a Compaq 1701 monitor and the video signal is missing, but you can see the background; the system (Pentium 4) and the VGA cable are OK; no OSD; please help me!
The fluorescent lamp has failed.
The LCD monitor has a "backlight" in order to illuminate the video images that you see.
It may be too costly to repair, since it may break again after repair.
New LCD monitors start at just under $100.
Quick fix, if you are brave:
With an open palm (not the PDA), whack the side of the monitor gently or not so gently to see if it works.
If so, you can either replace the monitor or put up with a sore palm.
Sep 29, 2009 | HP Compaq 1701 17" Flat Panel LCD Monitor
My phillips 42" HD Flat screen won't turn on
I switched the power cord with the one to my desktop monitor and it worked ..i noticed the end going into the TV had some discolor to it ..I put the one from the TV into my desktop monitor ..and that worked too..must of been a shortage of power from the cord to the TV?
Jun 11, 2009 | Insignia 42" LCD Flat-Panel HDTV
Compaq 1701 Flat Panel Monitor Powers Up but screen is blank
no when u power up the system press F8 key then u got safe mofde menu.
then go to enable vga mode then change resolutioin to 800 *600 or 1024*768
then apply and ok.
thats it.
Nov 11, 2008 | HP Compaq 1701 17" Flat Panel LCD Monitor
Power supply cord
Yes it is possible to get the product from HP(as now compaq is owned by HP). The part number of the product is 259055-001. You can ask for this product from HP by calling them at 1-800-227-8164. They may also give you a better alternative part number for the power cord. But according to me this particular part would be best for you monitor(259055-001). You can also buy this product online from hp.com. Yes in fact you can use sony pc tower to display on this monitor.
Aug 13, 2007 | Compaq FP 7020 17" Flat Panel LCD Monitor
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
HP Compaq 1701 17" Flat Panel LCD Monitor Logo
208 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
