Question about Kenwood KDC-MP4032 CD Player
KENWOOD KDC-W6537U HOW DO I TURN OFF DEMO MODE OFF AND HOW CAN I GET BLUETOOTH ON
Go to standby and scroll over too demo mode and that is the way to turn it off , i had the same problem
Posted on Oct 21, 2008
  • 1,512 Answers
Hi there
You can get the instruction book from here
http://www.kenwood-electronics.co.uk/WebFiles/File/uk/download/Instruction%20Manuals/KDC/KDC-W6537U.pdf
Page 29 tells you how to turn off Demonstration mode. Blue toothe operation is well detailed also. Good luck. Any problems, I have downloaded the manual to help you. :)
regards
Graeme.
Posted on Feb 15, 2008
How to turn Mode Demo . Off on my Kitchenaid Walloven
To turn off Demo Mode:
1. Press SETTINGS 12 times. "Demo Mode" and "ON. Press (1) to OFF" will appear in the display text area.
2. Press the "1" keypad to change the Demonstration Mode setting to Off.
3. "OFF Selected" will scroll in the text area. Demo Mode has been turned Off.
Nov 11, 2016 | Car Audio & Video
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
Jbl Pulse 2 stuck in Demo mode
Press and hold the * button for 2 seconds which should turn off the flashing lights.
Feb 23, 2016 | JBL Pulse Portable Bluetooth Speaker
How do I get unit out of demo mode...it is stuck and will not turn off demo mode
Here you go
Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the exercise bike is displayed in a store. If the demo mode is turned on,
the console will not turn off and the display will not
be reset when you finish exercising.
You can turn on or turn off the display demo mode.
From the settings menu, select Demo Mode. The
currently selected demo mode option will be
highlighted.
To turn on the demo mode, select On. To turn off
the demo mode, select Off.
Your manual is here.
http://www.sportsmith.net/images/product_support%5CProForm%5CPFEX013112%20-%20PROFORM%20LE%20TOUR%20DE%20FRANCE%20BIKE%5CPFEX01311.2-320509.pdf
Sep 19, 2015 | Proform Pro-Form Tour De France Spin Bike
How to turn demo mode off on Blaupunkt MP46 ?
go to settings and then in display find demo and turn it off there.
Apr 24, 2014 | Blaupunkt Bahamas MP46 CD Player
I went to the seceret setting screen on my nook hd and turned on demo mode and now i cant turn it off
access Settings > Device Information and tap above the volume bar while holding Volume + button, a menu pops up...unchecked "Enable Demo Mode". Turn off the Nook, turn it back on, demo mode should be off now.
-DO NOT- try and verify if demo mode is off before rebooting the device.
If all else fails, bring it in to your local B&N and seek the Nook specialist out. They should be able to turn it off for you.
Good Luck! :-)
Mar 24, 2014 | Barnes & Noble Nook
JVC KD-R330 Won't turn off Demo mode - tried instructions. Every time I follow the instructions (Turn on, Hold Menu, push "vol" button, change to Demo off...etc) It doesn't work. In fact, as soon as I...
Do you have a Bluetooth adapter plugged into the KD-R330?
A compatible Bluetooth adapter (like the KS-BTA100) usually plugs into the rear auxiliary port of the receiver. It then needs to be "paired" with your Bluetooth device, for example, a Bluetooth phone headset.
What you're describing sounds like what can when no Bluetooth device has been "paired" yet.
If you don't HAVE a Bluetooth adapter connected to your KD-R330....is it possible you accidentally plugged something into its rear auxiliary jack? Or the front auxiliary? In other words, is it possible your KD-R330 receiver is mistaking some other device for a Bluetooth adapter?
Don't know if that helps at all...if there's no adapter issue, and nothing connected to the AUX jacks, probably your next step should be a call to JVC, or whatever number you were given for tech support.
On the bright side, since the receiver turns on, and responds to some commands, you probably didn't mess up anything major in the wiring. And, there's also the possibility the receiver is defective....certainly if this continues, and JVC can't help you, trying a replacement might be worth a try.
BTW, feel free to post a reply...I'm going to look further to see if there's any other documented issue besides an adapter that might cause the problem you're having.
Oct 29, 2013 | JVC Car Audio & Video
How do i turn off demo mode
It is impossible to turn off demo mode as handsets in demo mode were specifically manufactured for demo mode. If you purchased the phone and it was in demo mode, please return it to the retailer and ask for a replacement.
Jun 23, 2013 | Nokia Lumia 920
I can't get my Kenwood KDC-X590 out of demo mode. Help!
Press the [MENU] button for at least one second. Push the control knob toward [AM] or [FM] to select "DEMO." Press the control knob for two seconds to alternate between "DEMO ON" and "DEMO OFF."
If you need a manual you may download a copy here.
Jun 15, 2012 | Kenwood KDC-X590 CD Player
Kenwood KDC-MP4032 CD Player Logo
649 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
