PL 100 After replacing belt on Pioneer PL100 the belt wants to crawl up on the rim of the motor pulley.
  • 281 Answers
If the belt if too tight or too loose, or if the pullies are not aligned correctly this will happen. Align both pullies correctly and check the belt tension.
Posted on Feb 15, 2008
Pioneer pl a45d
Hi Javier,
How to change the belt? how to replace belt on pioneer pl x300 pioneer pl x50 turntable .
A place to find the belt. Pioneer PL A45 PL A45D Realistic LAB 1500 TURNTABLE BELT T245
Manual with schematics. Sign up and free. Pioneer PL A45 Manual 2 Speed Belt Drive Turntable Vinyl Engine
How to set it up after you put the belt on.
How to set up Turntable cartridge alignment overhang VTA VTF vibration...
Another look on how to change a belt on a turntable? How to Replace Turntable Belt on Belt Drive Turntable
It is straight forward. Patience. Fare. Well.
May 16, 2014 | Pioneer Audio Players & Recorders
How install belt on pioneer turntable model PL. I tried slipping the belt on the inside ring and then to the pulley motor. but belt seems too loose and doesn't hold. is there an image how to do this? what...
The simple rule of thumb is after you lift up the turntable platter turn it upside down and see if the belt sits on the inner rim tightly. That is if you after putting the belt on the rim and shake it upside down the belt should not fall off. And if you want to measure the belt-- remove it and place it in cold water for an hour and then after wiping it clean place it on its flat side on a table ( best is glass surface ). Measure its length with out stretching it in centimeters and subtract about a centimeter from the total. This will give you a new belts measurement
Eg; If the belt measures 19cm, subtract 1cm from it and go buy an 18cm.belt for replacement.
Apr 03, 2011 | Pioneer PL-990 Turntable
How can iget the belt back on my turntable pioneer pl 990
PUT IT ROUND THE PLATTER BASE FIRST,THEN LOOP A BIT OF STRING ROUND THE BELT LONG ENOUGH, SO WHEN YOU PUT THE PLATTER BACK ON,YOU CAN LIFT IT UP A LITTLE BIT WHERE THE MOTOR WHEEL IS THAT TURNS THE BELT, PULL THE STRING TOWARDS IT SO THE BELT GOES OVER IT.DROP THE PLATTER THEN PULL THE STRING OUT.
Mar 31, 2011 | Pioneer PL-990 Turntable
Pioneer turntable is powering up but not not spinning?
Turntable Drive Belt
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Feb 18, 2011 | Pioneer PL-990 Turntable
I have an old Pioneer stereo auto turntable PL-5.It is rarely used and worked fine until my grandson started to turn the turntable by hand and I think backwards.Now it speeds up and races.Can this be fixed...
if the speed is constantly fast the drive belt may have ridden up on the top part of the motor pulley.inspect and refit.if the speed varies check operation of 33/45 switch.
Dec 15, 2009 | Pioneer Audio Players & Recorders
I have replaced the belt on my PL-990 and the pitch is off
Hiya, you can try cleaning the belt with iso alcohol or meths and also the platter and motor spindle. Make sure clen, flip the belt over, if that fails try a new belt, and if still not then the fault is electronic.
Best of luck
Jul 15, 2009 | Pioneer PL-990 Turntable
I have a Pioneer PL-A35 turntable. I had the belt
the may be a 'dead spot' on the motor, try to jump start it by spinning it with your fingers several times. it's a longshot but it might work
Apr 13, 2009 | Audio Players & Recorders
Pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
Jan 10, 2009 | Pioneer PL-990 Turntable
Platter problem
It sounds like the motor pulley is too high. try to screw down the pulley, maybe it came loose...The platter is designed specifically for the turntable and should fit perfectly in place....Another reason might be that the platter does not belong to the turntable, it might be too small and therefore sits lower than it should.
Jun 30, 2008 | Pioneer PL-990 Turntable
Pioneer pl 990
Remove any tape from the belt
That is the drive belt for the turntable .
It's not that hard to set up. Take the mat off the platter and wrap the belt around the underneath -slightly-less-diameter portion.
With a pointed end needle or something like it , put the tip between the belt and the platter portion it's wrapped against.
Pull the belt away from that( keeping the rest of the belt on the platter portion) and set it over the motor pulley. This is usually a small diameter brass spindle unit
Mar 27, 2008 | Pioneer PL-990 Turntable
74 people viewed this question
 Grubhead
Grubhead
