Question about Mitsubishi XL1XU Multimedia Projector
Bright then dark
I have a Mitsubishi xl1xu projector. On occasion, the screen will dim to where I can barely see anything. Then it returns to normal. Sometimes right away. Sometimes it stays dim for minutes at a time. Once this starts happening, it continues until I have to turn it off and wait for the bulb to cool. I don't like having to turn the projector off all the time, is there a better solution. (p.s. I'm using a new bulb)
  • 682 Answers
Check bulb life time if it is near end change it.
Posted on Mar 17, 2008
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Picture way too dark to watch comfortably. Have already adjust all settings to maximize brightness. Bulb was replaced late last year and says 1,000 hours have been used but projector has not prompted me...
Unfortunately dim image is normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image.
Aug 06, 2011 | Mitsubishi HC1600 Projector
I have my compaq presario cq60 laptop and i got a trouble on my screen which is the brightness become low and i can not adjust using the fn key plus f8. how can i adjust to return on the normal...
How low has the brightness gone? If it is very dark and you can barely see anything on the screen, it may be that the inverter board has failed and needs replacing.
The problem could also be caused by the screen itself, or the motherboard, but the inverter is the most common solution.
Jul 23, 2011 | HP Compaq Presario CQ60-249US Notebook
The Brightness of my tv is dimming can anyone enlighten me as to what mite be the issue, when I power it up the screen is black for a long time then when I finally get a picture it's very dark. I didn't...
If it is a tubed projector, it could be tired tubes. The EHT unit may be faulty. If it is a DLP or LCD then it could be a failing lamp. Job to tell with no information, sorry.
Dec 15, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Automatic power shut off
Hold right left and power all at the same time and it will reset...
Jul 23, 2008 | Mitsubishi XL1XU Multimedia Projector
The Protectiopn circut is working
Hi there
Did you check that your lamp hours were actually reset ?
Mar 27, 2008 | Mitsubishi XL1XU Multimedia Projector
Mitsubishi XL1XU Projector
Hi there
The most common cause for a Ballast to go faulty is power failures & power spikes and off course lightning.
I normally advise my clients to hook up a UPS to the Projector just to make the power supplied to the Projector more even and smooth.
Ballast problems however occurs more than often on any model of Mitsubishi I have found.
Oct 25, 2007 | Mitsubishi XL1XU Multimedia Projector
Blub brightness has dimmed.
Replace the Lamp unit is the best solution. that will cost you around $450.
Viren
Sep 08, 2006 | NEC VT460 Multimedia Projector
Mitsubishi XL1XU Multimedia Projector Logo
177 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
