Question about HP Officejet Pro L7680 All-In-One Printer
Inkjet refills I have refilled my inkjet cartridges with new ink (hp quality) and yet the hp printer does not recognize the new level of ink in the cartridge and warns that I need to get a new cartridge (even interupts print job with error signal) even though there is plenty of ink in the cartridge. Is there a way to reset the ink cartridge level ?
  • Anonymous Mar 19, 2014
    HP Designjet 5500 (42 in.) InkJet Printer error
  • Anonymous Mar 21, 2014
    How do I reset the ink levels estimated by the printer? I need to print some files, the printer is complaining that it's run out of black ink and refuses to even try printing.
    The black smudge of fresh ink on my pinky, directly from the cartridge, proves it false.
    Is there a way to trick the printer to think its cartridges are full.
    Sergeant:
    Champion:
  • 210 Answers
as you are using a refilled cartridge, it is causing this problem. the thickness of ink in a hp genuine cartridge and a refilled cartridge varies. and also the refilled cartridge may make your printer faulty. so it is good to try with a new hp genuine ink cartridges.
thanks and regards
agnel
Posted on Mar 18, 2008
Error code 0x610000f6.. would this be related to refiled cartridges
Hi paschal karl
The error code you are seeing may or may not have to do with the cartridges being refilled.
Here's the thing, yes, you can refill your cartridges or use re manufactured cartridges, but you may run into problems.
QualityLogic, one of the world's foremost quality assurance organizations, tested the performance of HP inkjet print cartridges vs. re manufactured (refilled) brands. The results: original HP inkjet print cartridges far surpassed ink refills in both print quality and reliability.
  • Nearly one out of every six refilled ink cartridges tested was dead on arrival or failed prematurely
  • 70% of refilled cartridges had some form of reliability problem
Count on HP original ink cartridges for consistent, worry-free printing. You may think you're saving money on re manufactured or refilled ink cartridges, but in the long run, the cost of wasted time, ink, and paper can more than make up the difference. -Source
Most people think, 'well of course that is what HP or an HP representative would say', but I have done some research and found that many others have too. Here is a perfect example of somebody who does not work for HP in any way and basically is a customer advocate (in my opinion) ;Should you refill your printer's ink cartridges? HP says no (of course) By Matthew Murray
I found the above article interesting and genuine.
To summarize, again, yes you can refill the cartridges. The printer is not programmed to reject them. Sometimes the cartridges will not work and of course because they are non HP, HP would not be able to do anything to help. HP cartridges have a 2 year manufacture warranty;Limited Warranty for HP Ink Cartridges and Customer-Replaceable Printheads for HP Inkjet Supplies, this may give you comfort knowing HP stand behind their product.
Perhaps you will find the following document helpful:
HP Printers Problem with Printhead Printer Failure Ink System Failure or...
I hope this helps.
I work on behalf of HP.
Jun 23, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
Canon mx700 not recognizing cartridges
I suspect that your have a damaged refilled cartridge. Also, you may have a clogged nozzle. Canon printers are sensitive to the quality of the ink used in the cartridges and refill ink sometimes does not meet the manufacturer's specifications. You can check this by inserting a new OEM cartridge, running the deep cleaning utillity three times and a aligning the printhead. The other problem may be that the electronic chip on the refilled cartridge may either be damaged or blocked by dried ink. In any case, you need to discard the failing cartridge and replace it.
Let me know if this solves the problem. Thanks.
Feb 22, 2010 | Canon MX700 Office All-In-One InkJet...
I just put in new ink cartridges and the color will print but the black won't print comes out blank?
How to Reset an HP Inkjet Cartridge
Hi there
Instructions
Things You'll Need:
Adhesive tape
HP inkjet cartridge can be refilled easily, getting it to work again in the printer is another matter.
The contacts on the back of the cartridge are programmed to read the ink level, but they don't reset for the printer just because you add more ink.
You must get the printer to recognize the cartridge as new.
You can do this easily if you have two other old cartridges, or you can manipulate the contacts on the refilled cartridge.
Step 1
Insert the cartridge you refilled into the HP Printer.
Have the printer print an alignment page, thus recognizing the cartridge. The printer will still read the ink level as where it was before you refilled it.
Step 2
Remove the cartridge from the printer and replace it with another old cartridge.
Have the printer print an alignment page with this cartridge so it recognizes it as a different cartridge from the first one.
Step 3
Replace the second cartridge with a third one and run the same alignment page.
Because the printer only retains the memory of two Print Cartridges, it will erase the memory of the first (refilled) cartridge.
Step 4
Insert the refilled cartridge into the printer.
The printer will now recognize the cartridge as being full.
Next Steps
Step 1
Tape over the contact squares on the top left corner of the cartridge's contacts. Insert the cartridge into the printer and run an alignment page. Ignore any messages that might appear saying there is a problem with the cartridge.
Step 2
Take the cartridge out of the printer. Remove the tape from the left corner and tape over the contact squares on the top right corner. Place the cartridge backs in and run another alignment page.
Step 3
Remove and reinsert the cartridge, this time with no tape on any of the contacts. Check to see if the printer recognizes the cartridge as being full.
Step 4
Repeat the above steps if the cartridge is still shown as being empty.
This time, use the bottom corner contact squares instead of the top ones. If you are still unable to reset the cartridges, using multiple cartridges is likely the only way to do it.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I refill my own cartridges. Printer says "Black Ink Low". I tried the "tape over the contacts" trick but it didn't work. How do I clear this error without having to cycle 2 other cartridges through it?
Use the fairy new cartridges offered by HP.
I realize they cost more but if there is a problem there is a warranty available from HP on their product.
The first thing refilled cartridges do for you is to cause any remaining warranty on the printer to be canceled.
Another benefit of refilled cartridges is most often poor print quality. Then of course, you can get stuck in the "Check ink level" or "Incorrect ink cartridge"
Refilled cartridges are not worth the time and effort you put into them, but hey that's just my humble opinion. I have seen firsthand what the damages can be with junk ink.
Don
Feb 14, 2010 | HP Officejet 4110 All-In-One InkJet...
I refilled HP 88 cartridge but printer (Officejet Pro L7590) still thinks cartridge is empty. How do I reset ink level?
Under the cartridge is a black like pump - on a new cartridge this is hard and rests firmly on an area inside your printer. As you print, the pump becomes softer - this is how the printer determines it is empty. Once refilled, the pump does not get back to the original state. Open the bottom of the cartridge and put a firm solid piece of folded paper in there - make sure it is steady and re-close cartridge. It will now read as full but may also show full - judge ink levels by the quality of print. Also make sure chip has not expired.
Nov 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
How to reset the ink level for a HP 60 ink cartridge? I have just refilled a HP 60 black ink cartridge but can not find anything on how to reset the ink level. I would do the "3 ink cartridge" trick but I...
You cannot reset the ink level indicator for the HP 60 ink cartridge. It shouldn't matter anyway because the level is only estimated for "management purposes only" (see user manual) meaning to let you know when it's near time to order a new cartidge. I have tried cycling through 3 different cartridges to reset the ink level for the one I refilled but it didn't work. Refill and just ignore the ink level indicator. Also, it's a good idea to clean the print heads with the solvent in the refill kit before refilling to remove old ink and imrpove print quality.
Apr 06, 2009 | HP DeskJet F4280 All In One Printer InkJet
My printer can't read the new ink level after refilling
The ink level indicator is only an estimate to give you an idea when it's time to buy a new cartridge. You cannot reset the ink level indicator so simply ignore it if you refill your cartridges. See pg 72 of the user manual which you can get here: http://h10032.www1.hp.com/ctg/Manual/c01374711.pdf
Dec 06, 2008 | HP DeskJet F4280 All In One Printer InkJet
Ink cartridge refills
hi,.
   the thickness of the ink in the genuine hp cartridge is different from the refill ink. it will never match. so thats it. try with a genuine hp cartridge and  check whether the printer works fine. else it might be the problem with the printer.
May 11, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
1,465 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
