Question about Sub-Zero 690 Side by Side Refrigerator
ICE MAKER SUB ZERO REFIGERATOR
ICE MAKER DOES NOT WORK ON MY SUB ZERO REFIGERATOR FREEZER SISE BY SIDE
  • 1 more comment
  • Anonymous Mar 15, 2014
    Help!
  • Anonymous Mar 16, 2014
    Ice maker
  • Anonymous Mar 22, 2014
    wont consistently make ice
    Problem Solver:
  • 7 Answers
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
  • Thomas Strauss
    Thomas Strauss Feb 17, 2014
    My white plastic flapper IS stuck on that white peg at top! How do I get it unstuck? The horizontal part of the u-shaped piece (wire as thick as coat hanger wire to which the plastic flapper is attached) is above that white peg. Thanks!
The ice-cube maker on our Sub-Zero 650 has stopped making ice.
try replace the cheapest part first.( vater valve). you only need 2 components to make ice. water valve and ice maker.is simple and easy water valve located in the bottom part of the unit. remove the kick plate. left side. and color blue. ice maker inside the freezer. (DISCONECT POWER BEFORE SERVICE. ALSO TURN WATER SUPPLY OFF.) try main box , garage. and water meter outside your house. good luck
Apr 02, 2010 | Sub-Zero 650 / O Bottom Freezer...
Water leaks into ice maker bin
2 possible causes. 1) tehe tube is not inside of the ice maker. 2)the ice maker has acrack. better to call a tech
Mar 13, 2010 | Sub-Zero 632 / S
My side by side G E Sub-Zero is not getting or staying cold on the refigerator side, the freezer is working, what could be the problem?
check to make sure the damper door between the freezer and refrigerator is operating and not iced up so it can open fully to let cold air in from the freezer compartment
Dec 25, 2009 | Sub-Zero 632 / S
ICE IS FORMONG ON THE BACK WALL OF A SIDE BY SIDE SUB ZERO REFIGERATOR.
This is typically a problem with the sealed system (refrigerant leak). Usually a circular patch of ice or water driplets half way down on the back wall. The solution involves replacing the evaporator coil. Subzero will give partial warranty up to 12 years.Full warranty for 5.A subzero authorized company is recomended.
Sep 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice maker made too much ice, then none at all...
buy the water valve and the ice maker. replace. water valve locate in the bottom part of the unit. remove kickplate. (left side blue color). ice maker little trick to replaced. (special the 2 screws in the upper part.) call 1800 222 7820. subzero. for your closest store
Sep 19, 2009 | Sub-Zero Bottom Freezer Refrigerator
Ice maker does not work in the sub zero 690
The fan seemed to not work when we closed the door so we taped the button to keep the fan running,
May 16, 2009 | Sub-Zero 690 Side by Side Refrigerator
Ice maker not making ice - repair costs?
switch the fridge off and try warming the ice maker workings up with a hair dryer.
Jul 11, 2017 | Sub-Zero 650 / O Bottom Freezer...
Cannot get ice drawer back on the track 500 series
Unfortunately, you need defrost freezer - put freezer thermostat on OFF. You possibly got broken ice tray or damaged sliders.Or leak in ice maker area. Till you defrost that compartment - no chance to pull tray out.
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jul 23, 2008 | Sub-Zero 632 / S
Sub zero 690 ice maker
also discovered if ice box auger not engaged exactly right with auger drive motor, then ice box won't be able to be pushed back the last half inch to engage the secret "turn on the ice maker" switches. Juice storage brackets also won't engage since ice bucket not flush with front of cover.
Jul 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
1,722 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
