Question about Whirlpool LGV4634JQ Gas Dryer
Whirlpool gas dryer
My Whirlpool gas dryer is starting up on its own. I went down and made sure that it was set in the off position thinking that I may have inadvertently turned it on. I walked away and later it started itself again. It has been doing this all day now. Thanks Chris
  • robert samples May 11, 2010
    look in the control panel and in the dryer for mouse droppings chewed wires etc
    Genius:
  • 1,198 Answers
I once found a mouse in the timer....gross. At least it was dried up.
Posted on Nov 25, 2008
I have a whirlpool lgq8611pw2 gas dryer. it has stopped producing heat. gas supply seems fine and other gas appliances work fine. Took front lower cover off and blew out dust> pulled and replaced...
go to this site..
I think the first item is what is bad. here's where to start.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-5-654402-/new/Whirlpool-Dryer-not-heating-LGQ8611PW2
Jan 07, 2018 | Whirlpool WGD5200TQ Gas Dryer
Gas drier Whirlpool LGR5634LQ0 drum turns, no heat. Turn off and restart, heats for a while then no heat for drying. Lint is clear, etc... Gas valve is in on position. Not sure what to do next. Check...
most gas dryers will have a problem with the 2 coils on top of the valve.
when these coils are weak or going bad, it will heat for a short while then no heat at all.
if you let the unit set for an hour or 2, it will heat again for a short peroid.
the coils are easy to replace, but do get both of them.
Mar 13, 2010 | Whirlpool LGR5634L Gas Dryer
Installed a new whirlpool gas dryer. no heat.
Well being "new" I'd not suspect many parts being defective other than the ignitor for the gas burner. You can view its operation behind the kick panel below the door. It should glow brightly when your dryer is calling for ignition. It may have been damaged if you had dropped it or very roughly handled your dryer wrestling it into position.
Otherwise i'd suspect that the gas line is still turned off, or a wire loose somewhere, or the heat setting in "air fluff"..
best of luck, and have fun,
ttfn
Feb 01, 2010 | Whirlpool WGD9500T / WGD9500TC / WGD9500TW...
I have a Whirlpool gas dryer LGQ7030K..the dryer does not turn on when start button is pushed.
If you open your dryer and the inside light isn't on - double check your breakers.
Also make sure the timer knob is set properly to a setting with minutes left.
Dec 06, 2009 | Whirlpool LGQ7030KQ Gas Dryer
Dryer flame starts for a few min then goes out
When it goes off will it restart immediately or do you need to allow some cool down time?
If cool down time is needed it's likely the coil kit which is part number 279834 for your model.
Other possibilities are air flow too slow causing a "lazy" flame which shuts off due to hitting safety thermostat sitting on top of the flame tunnel.
Aug 23, 2009 | Dryers
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
87 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
