Question about LG 42LC2D 42 in. LCD HDTV
Removal instructions for close caption
I do not know how to remove the close captioning appearing on some channels of my 42" LG HD Tv. Please help.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
If you are hooked up to a cable receiver, the closed caption must be disabled in the cable receiver. With most cable receivers the closed caption must either be on or off and there is not cc button on the remote.
Posted on Feb 19, 2008
Samsung LN-T4061F
To view the captions, all you have to do is turn on the decoder by following these simple steps:
  1. Access your TV menu screen using your remote or by pressing a button on the face of the TV.
  2. Select the closed captions heading. Several different caption options may appear.
  3. Select the "CC1" option.
  4. Exit the menu.
Closed captions should appear within approximately one minute of adjusting this setting. If they do not, review this portion of your television's operating manual or contact the manufacturer of the television set.
Public Television stations do not transmit Closed captioning
Apr 23, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Black box appears in middle of screen
go into the menu and look at the closed caption option----if TEXT is highlighted--this is your problem---select CC! or if it has it OFF.The TEXT will only appear on certain channels and it most likely was activated by someone changing the closed caption options. If this has been helpful give me a vote to let me know.
Aug 09, 2009 | LG 42LG30 42 in. LCD HDTV
Removing closed captioning
Worked it out. The Direct TV remote has a yellow button and that did it. I don't know whether I had inadvertently programmed it that way but problem gone.
Thanks.
Jan 18, 2009 | Philips 42PF9631D 42 in. Plasma Television
Toshiba TV 32AV502U - closed captioning
if you have satalite or a cable box the settings need to be changed in them for CC
Jan 08, 2009 | Televison & Video
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
Turn off closed caption on input(component) on Sharp Aquos 42"
I have a Sharp Aquos 46" and go a Comcast HD receiver as well, and had the same problem turning off the Closed Captioning. I order to turn it off you need to go into the box user setting by (starting w/ the cable box and tv on) pressing the power button for the cable box then the menu button for the cable box. This will open up the user settings menu. Just toggle CLOSED CAPTION to DISABLED.
Jan 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
Nov 27, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG LCD TV Model 42LB5D. The closed caption option is greyed out. Help please.
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
Nov 13, 2007 | LG 37LP1D 37 in. LCD Television
Closed Captioning on HD channels
We had the exact same problem just yesterday when we bought our Sony 46" Bravia LCD. Nobody, neither Comcast Cable or Sony seemed to really know how to get rid of the closed caption at first and we did have a Motorola box - the box is the problem, not the tv. Here is step-by-step instructions that worked for us. 1. While TV is on, power DCT (Digital Cable Terminal) off 2. Press and hold "menu" button on digital terminal (the screen below will appear) 3. Using Up/Down cursors, highlight "Close Caption" 4. Using Left/Right cursors, put - Close Caption: Disabled 5. Press "ok-select" 6. When done, press "power" to exit menu 7. Press "power" again to turn DCT on If you go through these steps slowly, you should have a caption-free screen!
Jul 09, 2007 | JVC AV-48WP30 48" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
457 people viewed this question
