Question about Saeco Milk Island Automatic Frother - EssentialEspresso.com
Saeco Milk Island
Is there a diagram for the top of the milk island which shows exactly how the little tube on the top of the milk island should be inserted. When I took the little triangular piece out of the top of the milk island a small piece (a small round tube which looks like a valve) fell out. I reinserted it in the hole on the bottom of the triangular piece where it seems to fit well. However, since this happened my milk island doesn't froth as well as it did when I first used it. I want to be sure I reinserted this piece correctly.
  • 10 more comments
  • marvinw Feb 14, 2008
    That picture is useless. I need to see how the disassembled milk island looks. Maybe I don't know what to do after I click on the link you posted
    My question has to do with what the little triangular insert on the top of the milk island looks like. You can only see this when you remove the milk island from its holder. Then the slightly rounded triangular section can be lifted up and underneath it there is a hole. I think the little valve fits into that hole. I just want to be sure. Inserting it made the steaming go a better, but not as good as it was originally.
    Thanks, I will await your posting. In the mean time do you know the answer to my question without finding the diagram.
    Actually there only seems one sensible way to put it in. That is, into the hole on the part which comes off, with the fatter round part on the outside. The fit is tight and easy. The result, however, is not great. On the other hand, the only other possible place to put it is into the hole into which the top fits. That way there is no tight fit, and things don't work better that way. I am pretty sure I have done the correct thing, but a diagram would be helpful.
    It is hard without a picture, but getting to it is done as follows:
    1. Remove milk island from its black plastic holder. The milk island is now in your hand. It is a glass unit with a black plastic collar and a softer insert into the collar which can be removed.
    2. On the top of the softer (rubber/plastic) insert is a removeable roughly triangular piece which can be lifted out. When you do so and turn it over you see two holes and a very short tube. These fit into matching depressions in the top. In particular the tube fits into a cylindrical hole which connects to the suction tube. I believe the little valve-like piece (it is just really a small tube which is a round collar followed by two flaps which snap together) fits into the hole in the bottom of the triangular piece. That way the milk which comes up from below will pass through it and push apart the little flaps. I think the fluttering action helps with the foaming. However, I could be wrong and it could fit in the hole in the top, although it doesn't make as much sense to me.
    I found those manuals too. They don't cover the milk island. The milk island manual which comes with it also doesn't have a parts diagram, so it is no help.
    I have read those posts. My machine worked perfectly. I cleaned it after each use. What happened was that after one such cleaning I found this small part on the floor. It had obviously fallen out. The question is, "From where ?". Also, "How should I reinsert it?"
    You aren't reading my posts. I know exactly where it came from. It came from the small triangular part that one removes from the top of the milk island to clean it. I just don't know whether to insert it into the hole in the triangular part with the sharp tip pointing in (the only way to do this), or to put it into the hole in the top with the sharp tip pointing down (I don't think this is correct). I want reassurance from someone who knows the correct answer.
    The only thing I ever find it listed under is Saeco Milk Island 0.4 liter. It is for the Talea Touch and new DeLuxe model.
  • marvinw Feb 15, 2008
    I have this manual. It just barely talks about the milk island.
    I have such a request in, I was trying to shortcut the wait by using FixYa
    Right now no experts seem to have any good suggestions, but I can wait and see what happens. I think you guys are just repeating what I did. I had hoped someone would know something more.
    Genius:
  • 3,422 Answers
Just clean all the parts in warm water after the use, as it wont have time to dry up and ruin it.. you should clean the island after each use anyway. Frankly, I don't think you will use the island much if you are the main operator.
It is not possible to find a diagram for your model only thing is you can do is try my solution if it doesn't work you have to get it repaired or replaced.
Most of the users have also reported the problem with frothing and the only solution was to get it repaired or replaced.There is no home remedy to fix this problem.
Goodluck..
Posted on Feb 14, 2008
  • 3 more comments
  • Priya darshan Feb 14, 2008
    It is not possible to say that but since it is a frothing problem the part must have fell from the bottom of the container.
    I suggest you to investigate each and every corner of the milk island i am sure you will find where to replace it.
    Open it up check inside properly..
    Yes even i don't think the sharp tip should point down as you said..
    What is the model no. of the milk island??
    have a look at this manual i hope the diagrams give you some idea
    Click HERE
    Waiting for your reply..
  • Priya darshan Feb 15, 2008
    why don't you try contacting the company . They might have given a support no. in the manual.check it out.
    You can always go for other experts suggestion if you wish to.
    I have tried my best,i was looking for the diagram and the service manual for 2 hours on the net but could nor find it.
  • 4,102 Answers
Hi have you tried or can you insert it the other way round or will it only fit one way because if it is a valve you might find that it should only be in one way let me know ok ill look for diagram in mean time ok speak soon
  • paul proctor Feb 14, 2008
    Hi researching now for you but is it like a little black plug that their after you take the holder off
    Genius:
  • 1,665 Answers
I dont think that there is a such diagram on the web.It is easier to see how it is inserted looking an assembled appliance.
http://shop.technikdirekt.de/es/a-haushalt+kleingeraete+espressomaschinen+zubehoer+123179/Saeco+Milk+Island
It doesn't froth properly
Trial and error solved the problem. The milk island is great but needs REGULAR cleaning. In order to clean properly one has to take apart the milk island and clean all rubber components of the dried milk that can and will accumulate. The most important cleaning taking place in all little holes as they are most likely to clog from the dried milk.
Jan 30, 2010 | Saeco Milk Island Automatic Frother -...
Milk island does not foam milk. i have the switch in the right position. how do i set the two part valve on the milk island?
Clean the milkisland valve,that is on top of the jug.Careful not to loose the small rubber valve which control the air to make foam.To set valve, one side for hot milk, and the other is for foam.
Jan 19, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Steamed milk is not coming out
Clean the steam wand, it unscrews and needs to be cleaned, also, descale the machine once the blocked tube is cleaned. When milk dries it is like glue and clogs the steam wand. so clean it daily after use.
Also, I think you meant to say, steam for milk frothing is not coming out. If you meant steamed milk is not coming out, it's not supposed to do that. Some Saeco's can add an attachment called a milk island but not the magic comfort plus.
Mar 04, 2009 | Saeco Magic Comfort Plus Espresso Machine
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Milk Island Error
Sorry for the delay, i´m on sick-list and not access to computer regulary:-(
It can take up to a week for the milk island to dry. check the gasket on the pin, that one you set the milk island on.
Have a nice day
/Mirran
Oct 13, 2008 | Saeco Milk Island Automatic Frother -...
Milk island error message
I think the problem is the arm where the carafe are connected, if there comes damp down in the arm then you can get this message.
/Mirran
Sep 21, 2008 | Saeco Milk Island Automatic Frother -...
Milk island seems to leak water. After milk is frothed and island has been detached fro some time, a pool of water forms under the base of the milk island attachment and on top of it.
Milk island on a vienna class?
Perhaps its a Saeco Talea you have, correct?
First remember that after foaming your milk and have turned the knob back to´off location. wait until you hear a clicking sound from the machine, might take 2 -5 seconds after it set to off.
Then remove the milk container
That sound means it has close 100% and shouldent leak.
If it still leaks after that its the gaskets in the T-pipe that needs to be changed.
Jul 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Coffee maker
I think that the electric board in milk island is gone and have to be replaced. If the milk island is leaking then it goes into the milk island and you get a short circuit:-(
Mar 19, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco milk island - no froth
I tried cleaning the thing throughout, and drying it on paper towels, but still no froth. Luckily, I bought the machine from a reputable dealer with superb integrity. He fixed the problem for me by returning the milk island and getting me a new one. It works perfectly now.
Nov 05, 2007 | Saeco Milk Island Automatic Frother -...
Saeco Milk Island Automatic Frother - EssentialEspresso.com Logo
471 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
