Question about Zenith C27A24T 27" TV
T V sound
Zenith T V bought in 2000-- dropped it and there was sred and blue on the edges then no sound I can use caption but that takes the joy out of watching t v
  • 40 Answers
Great ma ma- first of all if the tv was dropped,then there is a good chance that the pc board was damaged most likely a small crack near the audio section.This sort of repair is probably better left to someone with very good soldering skills. If you think you know someone,let me know I can help. cooltek Feb.15/08
Posted on Feb 15, 2008
The zenith is black in the middle the sound and picture ok
You have enabled closed caption when this is not supported by however your watching TV so you need to switch this off by firstly using the TV s own remote look for CC or "text" or subtitles and then press this button to disable closed caption, you may need to press or toggle the button several times to unlock this
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_70466cb634a57543
May 03, 2016 | Zenith Televison & Video
Zenith SL2773W problem
The dark rectangle appears because you have the closed captions on and set to TEXT. Closed captions set to CC1 puts the words on the screen and TEXT puts a black box on the screen. Go into the menu, navigate to the page with closed captions and set your captions to OFF.
Aug 12, 2007 | Zenith C27A24T 27" TV
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
How do I enable closed captioning on my Zenith PIP System 3? Thanks.
Hello
To enable close cationing on your TV follow this:-
[1] Press "Menu" button on the remote control to appear "Setup" menu on the screen.
[2] Use "Up and Down" arrows on the remote contol to select "Captions/Text" on your screen.
[3] Press "Right or Left " arrows to select any one of the following options. Caption-1, Caption-2, Caption-3, Caption-4 Text-1, Text-2, Text-3, Text-4.
[4] Press enter to return TV viewing.
To turn the caption feature to "On" or "Off'
[1] Press menu key on the remote control to display "Setup" menu.
[2] Using "UP/DOWN" buttons to select captions on your screen.
[3] Press "Right or Left" arrow to switch the captions feature 'ON" or "OFF" or "EZ Mute"
[4] Press enter to continue.
Ok.
Oct 22, 2010 | Zenith C27A24T 27" TV
Closed captioning disappeared.
unplug the set for several minutes, then reconnect.
Nov 03, 2009 | Zenith IQB50M90W 50" Rear Projection...
Captions only on certain channels?
Closed captioning isn't broadcast on every channel and program, so the information may not be present. Since captions are displayed on other channels, you know the set is working properly. If you are on a cable system you can try asking their customer service people if they know anything. But the TV is fine.
Mar 26, 2009 | Zenith B27A11Z 27" TV
Large Black Box Showing up in middle of screen.
Try and turn off the closed captioning. I had the same problem and it turned out that the closed captioning was on t1 instead of OFF. Hope this helps!!!!
Feb 19, 2009 | Zenith C27A24T 27" TV
How do i eliminate a black rectangular block on my 25" zenith tv?
You have the closed-captioning turned on and set to "text" mode. It's easy to do on Zeniths because many of their remotes have on button just to control the captioning. Go to the caption settings and turn it off or set it to "caption" mode if you want to use it. Then the box will be gone.
(What's happening is that in text mode, the screen is blanked out in the area where the text would go, but there isn't any text being sent by the station. On channels where no captioning at all is used, the box never shows up.)
Jan 19, 2009 | Zenith B25A11Z 25" TV
Add and delete chanel
I bought my Zenith in 2000 and it works fine but in moving it I dropped it and now I have no sound can you help me?
Jan 14, 2008 | Zenith B27A30ZC TV
Tv picture
Your closed captions are on and set to TEXT. Go into the menu, turn off the closed captions and the black box will vanish.
May 22, 2007 | Zenith SY2768S TV
Zenith C27A24T 27" TV Logo
51 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
