Question about Wacom Intuos2 6 x 8 10-Pack (XD68USBAC10PACK)
No free serial port
When I try to intsall the drivers for my tablet I go through part of the setup and it says i cant go any further because i have no free serial port. I dont know what this means or what to do to fix this, my tablet and my mouse are both usb so i dont know if that changes anything. Any help would be great.
I have a pansat box en i want to intstal it but it come can open serial port lasst error acces is denied
Posted on Feb 22, 2008
Dell M6500 w Eports Dock setup rollup Serial Dig. Tablet Works Can not find (10.09 ver)
The GTCO drivers only recognize Com ports 1 and 2, if you are using a serial port for communications.
If you are using the USB driver for Wintab, the drivers may not recognize the E-Ports.
I would try the USB driver and cable,(CAUTION) the RUD III,gets its power from the USB cable,so don't plug in a power supply and the USB cable.
Only use the USB cable when using the 10.9 drivers.
Jan 11, 2011 | GTCO Roll-Up III Digitizer
Wacom tablet stopped working, blue light on.
Since you are running Windows Vista on your PC this is the driver you should have downloaded.
Click Here
Serial cables are not hot swappable. The computer and tablet should be turned off before you plug them in.
Apr 10, 2008 | Wacom (PTZ930AC) Graphic Tablet
ERROR message "A Supported Tablet was not found on the system"
I have encountered this message a few times, usually if I have tried to plug'n'play the tablet. A restart with the tablet connected usually fixes it for me, but I would suggest removing the driver and software and reinstalling them, making sure you have the most up-to-date version- freely available from wacom.co.uk (though I note you have the latest versions so just reinstall those).
I think, however, your problem might be something to do with the following note from wacom:771c281.png Do you know if you are running a 64-bit setup? There may be a workaround even if you are, so do let us know.
Oct 28, 2009 | Wacom Intuos2
Bit of a problem installing Wacom Intuos2 with serial converter
you can check in the internet for the new driver and u can install like in XP and you dont find send the model number and the name and i will check for u
Nov 22, 2008 | Wacom (PTZ930AC) Graphic Tablet
Im using a serial to usb connector to connect my artZ II tablet to my laptop..
Sorry, I figured it out, it was because the serial to usb adapter i was using needed a driver, and then my computer recognizes it as an extra serial port. So, during installation it needed to be searched for automatically from my serial ports.
May 12, 2008 | Wacom ArtZ II (UD2-0608S-PC) Graphic...
Usb to serial adapter question
Try installing the Wacom USB drivers on the Mac. As I understand it, this adapter is designed to interact with devices that have their own serial drivers installed--such as a PDA, cell phone, camera, etc.--not necessarily with an input device, such as a drawing tablet, game controller, or pointing device. YMMV.
Dec 09, 2007 | IOGear (G-UC232A) Serial Adapter
Serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Dec 03, 2007 | Wacom (PTZ930AC) Graphic Tablet
Can not install ArtZ tablet
Check the port it is connected to. Wacom seems to only recognize serial ports 1-8. I use a USB to Serial adapter and had to reassign it to a lower port number from 12. Go into Device Manager, select the connected device, right click to select Properties, the the Port Setting tab, Advanced button, COM port number. Ok you way back out. uninstall the Wacom software, then reinstall it, following the reboot prompts. It loads a service that tends to hang if the device is not connected when it starts. I had started disabling the tablet and the service just so I can avoid a reboot when I change ports.
Oct 13, 2007 | Wacom (PTZ930AC) Graphic Tablet
Mouse jumping to bottom left corder randomly
What I'd try is go into the BIOS setup, and set your serial port for COM1 IRQ4 (Interupt) and 3F8H (address), if these latter notations are listed. Often, you will see the serial port, parallel port, etc. set to Auto. You may want to see if the PS2 port can be set to a specific Interupt and address also, just as long as the settings are not in use by another device. These kind of problems can be hard to pinpoint, but hopefully the above will solve your issue.
Jul 17, 2007 | AMD Multimedia Computer with Athlon64...
Wacom Intuos2 6 x 8 10-Pack (XD68USBAC10PACK) Logo
76 people viewed this question
Top Wacom Computers & Internet Experts
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Alun Cox
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
