Question about Sewing Machines
Bobbin clutch just spins
I have threaded the bobbin correctly, disengaged the clutch, and all it does is spin around. Any ideas? Thanks Gerry
  • ocala59 Feb 16, 2008
    Right, the bobbin does not wind. Clutch engaged, sews fine. Could it be a belt of some kind? Thanks.
    Thanks, that was what I was thinking. I can't wind any thread on my bobbin. I took the side off but didn't know what to look for. It's a New Home SD 2014. Think I'll take it in. Thanks a lot.
  • Sewing Machines Master
  • 1,388 Answers
Clutch is disengaged only for winding thread onto the bobbin.
When done, re-engage (tighten) clutch and with bobbin in bobbin case, hold needle thread, rotate handwheel until needle is top centre of it's motion then pull threads thru allowing approx 100mm (4") slack .....you are ready to sew.
If this isn't what you were asking, then I'm not sure why you have disengaged the clutch, so more detail please.
Posted on Feb 15, 2008
  • 1 more comment
  • Hassy
    Hassy Feb 16, 2008
    If you can take the top off the machine as a separate panel, you will probably find the bobbin winder runs by engaging a rubber wheel onto the handwheel, this rubber may be worn and need replacing, oily (and slipping) or broken into bits (and distributed inside the body of the machine, so make sure to retrieve all the bits).
    We don't know your Brand or Model, so this is best guess.
    Your local repair shop will probably have a replacement "bobbin winder rubber" for a few dollars......ring and ask with make & model details.....they can be a fiddle to replace as the available room is often limited.....you can take the entire unit off, BUT do it carefully and advise you take a digital photo of the B4 setting so you can refer back if it all goes pear shaped.
    If you have a newer moulded 2 section body, there are perhaps 18 screws located all over the place, as well as plastic clips holding the sections together, ........if you have the 2 section machine, get someone (service technician) with a service manual to do it, pay them and be happy to know it will come back in one piece.
    DIY at your peril and you will probably end up at the repair shop anyway, those 2 section machines (any brand) are cheap to manufacture and a pain in the proverbial to work on, esp. without a repair manual and limited knowledge.
  • Hassy
    Hassy Feb 16, 2008
    I don't seem to be able to add an image to this post at the moment, but if your SD 2014 is the older style machine (mid 80's), open the accessories lid on top, ident and undo 2 screws that hold it on, remove accessories tray.....you will see the bobbin winder stalk, underneath you will see the rubber driving wheel, probably with rubber residue around & near the site.
    You cannot see this with only the R side cover off, as the mechanism is driven (and hidden) by the handwheel.
    If you need the schematic diagram, email me via info@bargainbox.com.au
    Sometimes just turning the rubber wheel over will work as a temporary fix while you source a new one......if it is all oily, try a rag moistened with household spray cleaner to get some friction back between Handwheel & Rubber, but ....
    DO NOT spray the inside of the machine !!
    Gentle focussed application is required for this.
    Hope this helps
    Martyn
  • Hassy
    Hassy Feb 16, 2008
    Managed to get the images loaded this time......
    Applies to this SD 2014 from mid 1980's
    The red arrows indicate the bobbin winder (lower) once the top is removed (exploded view) and the hole through which it appears....the screws to remove top are shown to ease the journey !
    Phew
1320 will not thread bobbin
probably needs to be cleaned. the oil gunks up from lack of use with time.
Feb 21, 2013 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
I have a kenmore model # 1581212180. My top thread is looping and when I change the tension then I get where the thread doesn't even stay in the material. I don't have a manual any longer.
Sounds to me like your bobbin tension is way too tight. Adjusting the top thread tension will not correct this. Either something is binding up the bobbin (thread or lint) do you wind your own bobbins? Perhaps you have a little too much thread on the bobbin and it acts like a break, stopping the bobbin from spinning freely. Check, clean and oil your bobbin shuttle (the thing that spins around the bobbin).
Hope this helps!
Chris
glfi.com
Jan 20, 2011 | Kenmore Sewing Machines
I threaded it all right i have cheacked it many times but the thread in the bobbin keeps getting jammed
Many causes for this problem. Most common are;
  1. Top thread not inserted correctly.(must keep thread tight.)
  2. Debris and loose thread around the bobbin cage. All it takes is a tiny piece of thread in the right place.
  3. Bobbin inserted backwards in the "bobbin holder". When installed correctly, There is some resistance when you pull on the thread, but the bobbin will spin without trying to pop out of the "bobbin holder".
Oct 29, 2010 | Brother XL-5500 Mechanical Sewing Machine
ON MY 385 I CANNOT GET THE BOBBIN TO WIND THREAD
I know that it sounds silly but do you have your thread facing the right way? And around the guide the right way? And your clutch disengaged, either on the handwheel and or the bobbin pin lever pushed to the right? Are you holding the tail of the thread for at least 3-4 spins, the releasing? The only other thing could be that the tension looper is disengaged somehow. Good luck, seems like a major pain. I ended up buying a bobbin winder for about $30 for my mother's old machine, she is happy.
Oct 01, 2010 | Kenmore Sewing Machines
Threading the bobbin, disengage the needle
Depending what brand and model of sewing machine it is, you can usually disengage the needle bar with the knob inside the handwheel by turning it towards you. If you've done that and the needle bar still moves, it needs oil and should be serviced by a technician.
Feb 24, 2010 | Sewing Machines
Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
May 31, 2008 | White Sewing 2999 Mechanical Sewing...
Thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work)  Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
Feb 26, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
564 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
