Question about JVC HX-D7 Shelf System
I can't turn on
When turn on my compact component system display in the screen PROTECT
  • 1,512 Answers
Hi, I have given you a guide of how I would approach the unit if you brought it into my repair shop
  1. first check that there are no short circuits in the speaker wiring. This will cause the unit to go to protect mode.
  2. check each speaker with an ohms meter to see that the speaker itself is not faulty
  3. if speakers and wiring appear to be ok, I would check the power supply internally for any blown fuses.
  4. inspect under good light the soldering about the output stages and re-float where required
  5. Check for a DC offset condition on the speaker output IC for both channels then replace the IC if DC offset is found.
Generally this is the approach to a problem such as you have. If you don't have experience doing this sort of repair, then taking it to a repair shop is the best bet. Get a fixed quote on the repair first. Good luck, hope you get it going. :)
regards
Graeme
Posted on Feb 14, 2008
    Genius:
  • 3,422 Answers
The circuit is blown a couple of the connectors crossed. It is going in protect mode to keep it from further damaging the internal electronics. Open it up and double check all connections.But if you don't have any idea how to check it then i suggest you to take it for a repair,the cost will be between $100-$150.
You have to get it serviced and replace whatever has blown up inside and after that you won't get the protected message again.
Goodluck..
"PROTECT" message in display.
two cables of a speaker were touching each other.
this may be the problem
Dec 29, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
JVC MX-GT88 sound system showing protected them shut off why
Chances are that something is blown in the power output stages and units shuts down to protect against further damage.
Repair or replace, which ever is cheaper!
Dec 08, 2015 | JVC MX-GT88 CD Shelf System
Hello can u help me about my MHC-gzx55d sony hifi component, when you turn on the power, the screen display appear "PROTECT" what is the problem and what is the possible damage of my component. please help...
When it goes into protect mode it has been over loaded. Remove everything from the component and unplug the unit for a minute or two. plug it back in and see if it pops out of protect mode. If this does not work then you will need to do a factory reset or check the fuses on the inside of the unit.
Feb 20, 2015 | Sony Audio Players & Recorders
Stereo
You will need to change the audio output ic in the stereo to reset it.
Mar 07, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
Every time iturn on my stero it says protect what is the problem and what can i do to fix it
u have a short... find a short u left by... it says protect because the stereo protects itself from shorting out.
Apr 10, 2009 | JVC Silver/brown Compact Component System...
PROTECT DESPLAY CAN NOT RESET ON SHARP MODEL CDK7000
protect display on my sharp mini component system, how do i fix this problem
Feb 21, 2009 | Sharp Audio Players & Recorders
Display says protect
check your low voltage fuses, the protect light up when a overload comes....
Jan 28, 2009 | Audio Players & Recorders
P-Error on JVC compact component system FS-GD7 when turned on
1. Unplug the JVC compact component power cord from the power outlet.
2. Unplug any connected devices.
3. Press and hold the JVC compact component power button for five seconds.
4. Plug the JVC compact component power cord back into the power outlet and turn on the JVC compact component
5. Open the menu to confirm that the JVC compact component is responding again.
6. Turn off the JVC compact componentand reconnect the devices.
7. Turn on the JVC compact component...
Jul 23, 2008 | Audio Players & Recorders
PROTECT message display on JVC HX-D7 DVD Stero Player and turn off
That could meen that something is improperly connected. You should try to disconnect everything, and then reconnect it step by step.
Oct 11, 2007 | JVC HX-D7 DVD Compact Stereo Audio / Video...
JVC HX-D7 Shelf System Logo
81 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
