Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Black Line Down Center of Page
Whenever I used the document feeder to make copies, a black line prints down the center of each copy. If I use the platen glass to make copies, the line does not appear on the copies.
Any idea how to make this stop?
Thanks,
Mike
I had the same problem. I cleaned the strip above the glass and this fixed the problem. Hope it helps!
Posted on Mar 14, 2008
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Hp 6210 prints a black line down the center of the page. 1st 50 copies okay, then line started.
First diagnose if the line comes when using the doc feeder or the glass. If it only comes when using the doc feeder then you have a small dirt spot on the glass where the page is scanning over the exposure lamp. Just clean it.
Feb 10, 2011 | HP OfficeJet 6210 All-In-One InkJet...
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
Black lines down on printed page
This is caused by dirt/debrise on the ADF (automatic document feeder) scanner glass. You need to open up the feeder where your originals are fed in and look for a strip of glass that runs from front to back. It is about an inch or so wide. You need to clean this glass to get rid of the lines. Some models have this glass just to the left of the large main glass, but in your case I beleive it is in the feeder itself.
Good Luck.
Apr 23, 2010 | Brother MFC-7820N Printer
Black line off center of printed page
open the doc feeder and clean the scanner glass with alchol
Oct 02, 2009 | Brother Office Equipment & Supplies
Black line when using feeder
Not familiar with this model in particular, but if you lift the document feeder, as if to place an original on the glass, there is either a narrow filter glass on the left of the main contact glass, or in many cases it is attached (clipped on) and lifts up with the document feeder cover. Clean this glass. If it is clipped on to the cover, remove it, and clean both sides. I hope this helps.
Please rate solution :)
Apr 24, 2009 | Office Equipment & Supplies
Black line while scanning and copying
Open up the document feeder and clean the scanner glass
Jan 25, 2009 | Brother Multi-Function Center MFC-240C...
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
334 people viewed this question
old marine
old marine
