Question about Sanyo HT32744 32" TV
No power hi there I have a sanyo ht 32744 when i press the power button it makes a few whining sounds in a row then clicks and wont power up any ideas?
  • 2,130 Answers
It sounds like you have a problem in the set's power supply or high voltage section and the set is protecting itself from turning on. Unfortunately, you'll need to take it to be serviced.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 15, 2008
Samsung HT-THX25 sound problem
I had the same problem. How i fixed ? I unplugged HT and I kept pressed the power button from DVD for a few seconds. Repeat it, put it in socket and turn it on. It happens from condensation or voltage variations.
Sep 19, 2012 | Audio Players & Recorders
When you press the power button the projector light is green for a moment and making a sound as if it is turned on but no screen appears then after a few seconds the red light comes on. The lamp replacment...
I hope our talented expert would have given you helpful and correct info in chat session from related service manual, feel free to ask further help if required.
Thanks.
Sep 30, 2010 | Sanyo PLC XU35 Multimedia Projector
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Whining when i press gas
normally, the only part of your automatic transmission that will make a whining noise is the pump. it usually whines when iether the fluid is low or more commonly when the transmission oil filter is getting plugged up.
the power steering pump will also make a whining noise too.
turn the wheel all the way to the right and hold steady pressure against the stop. this puts maximum force on the power steering pump and, if the power steering pump is the one making the whine, it will change the sound of it. (usually louder).
if the trans pump is making the whine noise, it should sound different in neutral compared to drive. this test will really only work if it make the noise without the vehicle moving. if it wont do it at idle hold the rpms at 2000 or so.
if you decide the noise is coming from the transmission, and the transmission filter has not been replaced (assuming you installed a used transmission), replace the filter by removing the oil pan.
oh and also, if it is the power steering pump you should be able to make it make the whining noise while the vehicle is stationary. if it wont make noise unless its moving its not the power steering pump.
Mar 23, 2010 | 2003 Chevrolet TrailBlazer
Prima HT-TW57P (Home theater wont turn on)
Hiya, Sorry to say it does sound a little like there is power supply damage. They are generally not to difficult to sort out but will require someone with electronics experience IE friend, shop in the area etc. Shouldn't be to much provided it is only power supply
Jul 10, 2009 | Audio Players & Recorders
When i turn on my samsung 62'' inch rear projection tv(model#HLR6167WAX/XAA) it begins to whine like a fan working overtime, I will get a picture for about 5-8 seconds, and then it will cut off and the...
Hi.The ballast may be defective if you hear constant clicking sounds after you've pressed the power button.
If there are no clicking sounds after you press the power button(3-5 clicks every 2-3 seconds), this will confirm optimal ballast performance and, it will also confirm a major issue that concerns the Power distribution board. There are several weak or damaged components on the board that have failed.
The replacement of the power board is recommended in this case.
Jul 08, 2009 | Samsung Televison & Video
Region codes for Samsung ht z110
Try this
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
Apr 25, 2009 | Televison & Video
Dryer wont start
Your motor is bad.
Apr 19, 2009 | Dryers
Model #
The solder joints on the CRT board might have cracked and cause this symptom. What you are describing indicates that the red gun is intermitten, and the solder joints on the CRT socket itself (red cathode) or the red output transistor have probably cracked loose.
Aug 23, 2008 | Sanyo HT32744 32" TV
Region Codes
1. Disconnect your player from its power source for thirty seconds
2. Reconnect your player to its power source
3. Press the Power On button on your remote control
4. Press the Enter button on your remote control
5. Press the 8 button on your remote control
6. Press the 4 button on your remote control
7. Press the 2 button on your remote control
8. Press the 6 button on your remote control
9. Press the 9 button on your remote control
10. Press the Enter button on your remote control
11. Your player should now place itself in Standby mode
12. Press the Power On button on your remote control
It should also work for HT-Z310T and HT-510T and its variantes...
Apr 12, 2008 | Samsung HT-Z310T Theater System
Sanyo HT32744 32" TV Logo
259 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
