Question about Belling XOU592 / XOU593 Electric Double Oven
Grill problem I noticed that the grill element was cycling on/off on a low setting even though it was switched off at the oven control. I now have to switch off at the mains to stop this happening. Can anyone advise me.
  • Andrew Tissington Feb 18, 2008
    Very impressed with the speed of reply. Fault now sorted. Thanks
  • 4 Answers
YOUR PROBLEM IS WITH THE GRILL SELECTOR SWITCH REPLACING THIS WILL CURE YOUR PROBLEM.
Posted on Feb 14, 2008
Bosch oven temp control
If the temp control works for all other settings, it is working for hot air grilling as it using the same stat....when hot air grilling function is used the grill comes on and when it reaches temp the element switches off and the fan switches on. Once this has happened the element and fan will alternate during the cooking period. The fan and element DO NOT operate at the same time.
Mar 23, 2013 | Bosch Ovens
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Please could someone tell me how to use the grill?
First things first, the grill only works with the door down. Directly you shut it, a microswitch operates and shuts the elements off. ( Of course the top oven operates with the door shut).
There are two options for the grill. Turning the control switch to the left operates the inner element only. Turning it to the right operates both the inner and outer elements together.
With either option, setting 5 (the max) has that option on full, whereas settings 1 to 4 switch on and off.
Nov 10, 2010 | Stoves 720EF Electric Double Oven
Element won't heat on oven setting but does on grill setting any ideas on problem
The element for the oven is separate from the grill element. As you haven't specified your oven brand or model, I can't say that with 100% certainty, but every oven I ever seen has separate elements for grill and oven.
It's most likely that your oven element is burnt out. To check this, you need to get access to the oven element and (with the power off) test for continuity/resistance across the live and neutral terminals of the element. You'll need an Ohm meter to do this.
If your oven element checks out, the next things to check are the oven switch, thermostat and the wiring from the oven switch to the element.
I'd guess your element is burnt out. Common problem, especially if you've had the oven a while.
Please rate my solution if you find this helpful. Thanks.
Oct 16, 2010 | Ovens
Because I haven't got a manual, and the oven is slightly worn, I would like to know what the symbol at the eleven o'clock position on the top oven control knob means. There are 2 symbols that appear to be...
There are two controls for the top oven and grill.
The far left one is purely for the oven and oven lights. The middle control of the three on the panel is for the grill. The grill will only work when the front is down, there is a micro switch that controls this.
The grill control is a dual action control. Turn it one way and it is the full grill, turn it the other and it is only the inner element. Left is the small grill, right is the larger, full grill. Oven lights do not come on with the grill control, you have to turn the lights on with the oven control.
The oven has a small element so takes a long time to heat up.
If you need a copy of the handbook, supply an email address and you can have access to my BT digital vault where a copy is stored.
Dec 10, 2009 | Stoves 720EF Electric Double Oven
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Ovens
My astro x oven will not heat up, the grill still
Sounds like the heating element has gone. if you can see thee element sometimes you can see damage like a hole or melted metal with white residue
Aug 02, 2009 | Fisher and Paykel Ovens
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Belling XOU592 / XOU593 Electric Double Oven Logo
214 people viewed this question
Top Belling Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
RudeRude
Are you a Belling Oven Expert? Answer questions, earn points and help others
