Thank you for adding me as a buddy, I am so confused with this, I tried a little bit of everything, and nothing is working...how can that be possible? ?it was brand new, I loaded my files and music played it for a while and tried to charge it and the cords will not fit, it looks like something shrunk
  • 21 Answers
I think we can fix it once we talk. I have an idea o fwhat the problem may be.
Posted on Feb 14, 2008
  • John Schafer
    John Schafer Mar 04, 2008
    I have been sick in the hospital for almost 2 weeks. Did you ever get your player working?
Dryer was working fine until I turned off the breaker to work on an electrical outlet on the same circuit. When I was done I turned on the breaker all other outlets worked, I went to use the dryer and...
Hello Steve,
I am a bit confused because the model you selected is for a electric dryer which should have a dedicated outlet/breaker only for the dryer
I am going to assume it's a gas dryer and the trouble is with the outlet,to verify this plug a know working object into the outlet and see if it works
Even if the part in the dryer part that cuts the circuit to the motor if it's bad(thermal fuse) has no bearing on the drum light and that should work if power to dryer
Gene
Jul 29, 2011 | Estate TEDS840JQ Electric Dryer
I have added the gas in my A/C at home but no air flow from vent
Your message is a bit confusing but since there is a vehicle model shown, I'll assume that is the A/C causing problems.If the blower does not push air on either heating or A/C settings, the bearings of the motor may have gotten gummy and are not allowing the motor to spin up. Check the different speed settings for the blower, preferably with the controls set to heating since there are additional controls when on A/C that can confuse troubleshooting. If the highest speed is working, then the speed control resistor has failed. If it does not move air regardless of setting, then the blower motor has failed or the bearings sticky.
If you have added gas to your home A/C, I hope you know which gas is used (R-22- NOT R-134 as in cars) and have not overcharged it since that can caused very high pressures that can damage your system. Different systems also have different intake and output pressures with which the compressor and other system components work best.
Jun 26, 2009 | 1999 Acura TL
Teamspeak Won't Work with Vista
Look at TeamSpeak overlay with PlayClaw. The main task of PlayClaw is to record game video but it have ability to show Teamspeak & Ventrilo overlays. Works fine with Vista/W7, but only one restriction - voip client must be 32 native (not 64) app. Windows may be in any bits: 32 or 64
Nov 21, 2008 | Computers & Internet
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Error 61:00
I found this on another website. After trying the bang and blow method....I found that it really does work!!!! I thought I was going to have to buy a new camera. I am SO thankful to have found this. I hope they don't mind me reposting it on this site.
Added by Phillip Ewing on 04/Jan/05 at 04:44:53
We had the same problem, and we fixed it! First, identify that it''s the AF motor drive by A) Turning it on and putting your ears against the camera, then hearing a humming noise for about 5 seconds. B) The error comes up flashing on the screen: "E:61:00". Okay, so you''ve identified your problem! Next you wanna fix it, right? ;) A) Put the camera about a half inch from a hard surface. B) Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time. If that doesnt fix it, try this: A) Turn it on and let the lense go out fully B) See where the lense comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!) Now turn it off/on again, and it should be fixed! If not, try these steps a few more times. If still nothing, then I suggest phoning Sony, but this DID work for us, so hopefully it''ll work for you :)
Mar 14, 2008 | Cameras
 Grubhead
Grubhead
