Hi, firstly check that the discs are not too scratched and be aware that CD's read and play from the inner diameter to the outer diameter. CD players are really finicky devices that can be affected by the slightest bump and also temperature and humidity changes. Sometimes decks have a humidity sensor embedded in the circuitry. So, all that being said, firstly just turn the set on and let it sit for a while to heat up and dry out especially if it hasn't been used for a while. Then, take the lid off and check for broken drive belts that actually spin the disc. (You may be able to hear the disc spin without the top off). After that the laser itself will have to be cleaned, adjusted and the current checked. Lasers do wear out and sometimes increasing the current to the laser will make it read for a little while longer. You will need the schematic diagram and some decent equipment and knowledge to achieve this though. Since they both don't work, and you got them for free, they might be good experimental pieces but, in my experience they are never 'time' worthwhile repairs. Good luck. Cheers
hey all ive a dns3500 that will not completely load the cd.......
if i take the fasia off the front i can load the cd......
does anybody know if the cd mechanism needs a rubber band that needs to be replaced?? also does the dns1200 have the same cd transport mechanism cos i could swap.......
thanks
If you would like to change the fuse yourself here is how:- Use a flat screwdriver or a knife and insert it where i have marked in yellow. Then push the plastic lid out with the picture of a fuse.Replace fuse and press the lid back.
I'm having a similar problem. Basically I put it a disc, and the song titles show up, but it takes over a minute for an actual song to load. I don't have a solution, but I am in contact with Denon, and they're, so far, pretty cooperative.
Hi. this denon error code is signaling an issue that concerns the loading deck and optical lens assembly. in this case, the entire assembly will need to be replaced asap if possible
Please reset the unit for 4 hours by unplugging all the cords,even the power cord from the unit and then plug them back again after 4 hours.Now try ejecting the disc.Let me know the result.
Sounds like it may need a motor calibration. You would have to seek out an authorized service center to this adjustment done. It's a quick and easy fix though.
