Question about Gateway MX6625 Notebook
Audioplug My audioplug, where i plug my earphone, popped out and it needs soldering. Can someone tell me how i can properly and correctly solder the audioplug back to the motherboard of my Gateway MX6625? The inside of the audioplug had two gold skinny plates on each side and one of them came loose. I need to know how i can solder it correctly that when i plug my earphone into the audioplug, sound should be coming into my earphone and not continuing on the speaker.
  • mobile logu Nov 01, 2008
    sound is coming only earphone after i will remove the earphone sound is not coming the speaker
  • 58 Answers
Well opening your laptop would not be an easy job. You might damage it because to get to where you can solder it you have open it up.
I suggest that you can buy this usb adapter and you will have earphone and mic.
http://www.monde-tech.com/product_info.php?language=en&currency=USD&products_id=111
This is just a suggestion.
Posted on Feb 15, 2008
Sound does not transfer from laptop to earphones when they are plugged in. Tested earphone and test was good. How do I get the sound to come out of the earphones instead of laptop?
I would guess there is a fault with with the earphone jack socket, the soldering to the printed circuit board or perhaps some of the electronic components that might or might not provide attenuation and/or tone correction for the earphones.
Probably be a cheaper cure to use bluetooth.
I use a usb FM transmitter so my sound files can be played on any nearby FM radio.
Dec 03, 2015 | Compaq Computers & Internet
Input jack on my hp541 kicker headphone's sound comes and goes. I have tried multiple cables, If I wiggle the cable around it works in one speaker sometimes both.
Hi hotrodjayrod,
If the symptoms remain the same after trying another headset, this kind of fault is caused by bad solder joints in the earphone jack itself of your unit. This is due to frequent inserting and pulling the headset plug. To resolve the issue, the earphone jack must be re-soldered. You have to open the back cover of your player and using a pointed soldering iron, re-solder the joints.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 20, 2011 | Kicker HP541 Headphones
No matter what set of head phones i plug into to my lyra rca mp3 player the left ear phone won't play anything
Most of this symptoms is a caused by bad solder joints on the earphone jack of the player. The unit must be take apart and re-solder the joints of the earphone jack. You need a pointed soldering iron to do this. If the symptoms still persist, the fault is in the audio circuitry. You must sent it in because this is not DIY, parts are too small and surface mounted.
Hope I helped you.
Have a nice day!
Jul 25, 2011 | Audio Players & Recorders
Can I replace plug on my Denon overear headphones
If the cord is broken at the plug, most standard sub-mini,mini phone plugs can be replaced by someone with a little skill at soldering ( a ohm meter also helps). Get a replacement stereo plug like the old one (often at Radio shack or any electronic parts store). Cut off the old plug and carefully strip off the outside insulation back about 1/4". Note there is 3 conductors. The webbing around the 2 wires goes to the outside back end of the plug. This is the ground or common wire for both sides. This wire may have a non conducting coating on it which needs to be stripped off before you solder it to the plug. There is 2 other wires in the cord. one (often red) is the right channel and the other is the left. You can check which channel is the right side with a meter or a AA battery. DON'T try to check with the earphones on your head!! The right 'hot' side will go to the tip of the plug and the left side goes to the ring next to the tip. Don't forget to strip off the insulation of the wires by gently scraping them with a sharp knife or razer blade. Also don't do like I sometimes do and forget to put the collar or back piece on the wire before you solder the wires on the plug. Hope this helps.
Dec 29, 2010 | Denon AH-D1001 Headphones
What can I do to fix a cable issue in my headphone? The right side doesn't work unless I move around the wire attached to the headphone.
Hi, what makes oneofthe earphones not to work,is because the wire inside the right side of the earphone hascut and will need to soldered back to it's position.
Open the right side of the earphone,and use a soldering iron and a lead to put back the wire properly.
after put back the wire,problem solved.
Thanks for using fixya..
Oct 27, 2010 | Skull Candy Ink'd Stereo Ear Bud...
When I plug the earphone jack into my MP4 player, I only get sound from one earpiece. I have tried several earphone sets to determine that it is not a problem with the earphones
Hi, this is a very common problem, after you have pulled the ear phones in and out a few times the solder on the earphone socket becomes brittle and breaks making you lose the connection with the circuit board, now as you have ruled out it being an earphone fault then the only possible problem could be the solder.
now sometimes if you wiggle the earphone at the part that goes into the mp3 you can sometimes get the sound working again, but this dont always work so dont rely on this,
now the problem you have is that the cost of getting this part fixed would cost a lot more than buying a new mp4 player.
the cheapest place to try and get this fixed is a tv repair shop, tell them exactly what the problem is so they dont have to test it and see how much they will charge you to resolder the earphone socket back in place properly.
that would be the cheapest option and could possibly get it working again if they will do the work for you
im sorry their is no easy fix but without getting the earphone socket re-soldered it will just never work
let me know if you need further assistance ok
Aug 18, 2010 | Naxa Electronics Audio Players & Recorders
Only one earphone works and its not the problem of earphones
if the earphones are fine then it is usually a problem with the audio jack. Either the contacts that push on the barrel of the earphone plug have gotten worn out or a connection that is soldered to the board has become bad.
In this case you really have one of 2 options How long have you owned the unit.. if it is still under warranty then have it repaired under warranty by the manufacturer. If it is not under warranty call Apple and ask them how much to get it repaired then base out if it is worth to pay to get it repaired or is it worth buying a new or used product of the same caliber. But id say in my experience its worth it to have them repair it. its actually not that hard to solder on a new headphone connector just takes someone with alot of skills and the tools to be able to desolder the old one and put a new one on.
if you need further assistance i will be here to help. Thanks and have a good day.
Aug 17, 2010 | Apple iPod MA446LL/A MP3 Player
Battery replacement norelco t7500 shaver
If you know how to solder, it's easy to replace the rechargeable battery in the Norelco T7500 shaver, thanks its beautiful mechanical design: You just remove the single screw at the bottom, and the entire charging circuit board & battery simply slides out, still attached to the shaver by a folded ribbon cable!
Then, you just pop off the plastic shields, unsolder the battery, and solder in a new AA 1.2V NiCd solder-tail battery. Or, you can use a higher-capacity AA NiMH battery for a longer run-time, at the expense of fewer recharge cycles for NiMH.
In either case, dispose of old NiCd batteries properly: They contain cadmium, which is an environmental poison!
Jun 23, 2008 | Norelco Cool Skin 7775X Electric Shaver
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
I can only hear out of one ear of my ear phones and sometimes I hear no sound at all
Perhaps you can open the player and solder the head socket it may have some dry joints there.
Jul 24, 2006 | Dell Pocket DJ MP3 Player
Gateway MX6625 Notebook Logo
87 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
