Question about Eureka 5197AT Upright Vacuum
Eureka 5197 self propelled bagless upright
I changed the filters and unclogged it and changed the belt. Suction is fine but it is extremely loud and smells like the belt is burning? How do I fix?
  • Anonymous Mar 17, 2014
    eureka as5200 loud squealing belt fine
Ok, i guess it is the motor then because i checked the brush and it turns and the belt seems to be okay now, just loud motor.
thanks for the help!
Posted on Feb 14, 2008
    President:
  • 1,673 Answers
Did you check the brush roll when you changed the belt? The smell of rubber would inducate a belt slipping. So if the brush roll (part #61308-2)isn't turning, the belt would get hot and would be slipping. If the motor sounds real loud, then you could have a bad motor(part #60775-4).
VACUUM BEATER BAR WONT TURN AND NO SUCTION ON FLOOR. LOTS OF SUCTION FROM HOSE.
If the belt is stretched it will not pick up properly. Try replacing the belt first. Belts should be replaced at least twice per year.
Feb 24, 2015 | Bissell PowerGlide Deluxe Pet...
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
My vacuum is loud and dies
your impeller is broken that make motor work harder and shut off
Oct 14, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
LOUD
You might need to change the drive belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Sep 16, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Suction
absolutely all the air in a vacuum would pass through the filter and if its clogged badly you could loose all your suction and if the belt is more than a year old then replace it even if it isnt broken ( they stretch out over time )
Sep 17, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover self-propelled
No suction on Windtunnel 6630-900. All belts work, brush turns, it just won't pick up anything.
Sep 07, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover Wind Tunnel Upright Self-Propelled
Thanks to reddevil6. Sure enough it was the belt. What I did was take off the belt and flipped it over, worked like a charm. Since it was stretched on one side the other side was still ok. Still need a new, but s aved me a trip to the store!
Nov 21, 2007 | Vacuums
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Eureka 5197AT Upright Vacuum Logo
419 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
