Question about Vacuums
Eureka vacuum belt how do i replace on model #4688
My vacuum is not picking up.
  • Anonymous Mar 30, 2014
    Need a quick start guide for a Eureka vacuum model AS 1008
    Problem Solver:
  • 17 Answers
How To Replace Brush Roll Belt
NOTE: Turn off the switch and unplug the electrical cord
before replacing belt. Belt pulleys can become
hot during normal use. To prevent injury, avoid
touching the motor shaft when checking the belt.
1. Lower handle to floor to change belt.
2. Loosen, but do not remove, two screws to release hood.
Lift hood to remove.
3. Lift left end of brush roll.
4. Remove and discard belt.
5. Place new belt around motor shaft.
6. Place belt around brush roll pulley.
7. Align left end cap with base. Push end cap
securely into place.
8. Pull right side of brush roll to stretch belt.
Secure right end cap into base.
9. Rotate brush roll to seat belt.
10. Replace the hood. Make sure hood front is
behind furniture guard. Hood should seat
onto self-locating screw tabs.
11. Tighten screws.
You can goto this website enter in the model number 4688 and you can see detailed pictures of how to change the belt as well as print off a new user manual.
http://www.eureka.com/servlet/FindOwnersGuide
Regards
Posted on Feb 14, 2008
Belt is off
You need to replace the belt. Over time they stretch and wear and then don't stay on and make it so the vacuum doesn't pick up well. Here is the belt you need and a manual you can view which has instructions:
Eureka Maxima Belt and Manual
Feb 07, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
My eureka vacuum won't suction and starts to smoke when I try to use it. It sounds like it is suctioning when I first turn it on, but after about 20 seconds it begins to smell like burning and does not...
The problem is that your belt is stretched and worn. This causes that burning smell and it also causes the vacuum to not pick up well. You need to replace the belt. Here is the belt you need and the manual with instructions:
Eureka Altima Belt and Manual
Jan 31, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a eureka altima bagless and it wont pick up dirt i clean it and everything it just wont work
The belt is probably worn, stretched or broken that is why it is not picking up. Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 20, 2009 | Eureka Capture Upright Vacuum Vacuum
Not sucing
The reason it is not picking up is probably because the belt is stretched, worn or broken and is not turning the brush the way it should and therefore not picking anything up. You should change the belt on your model at least once a year. Here is a link to the belt you need and a link to the owners manual which has belt changing instructions:
Eureka Capture Replacement Belts
Eureka Capture Owner's Guide
Nov 08, 2009 | Eureka Capture Upright Vacuum Vacuum
Not picking up. suction okay on tools. I think belt is broken but how to get to it and change it?
Yes, you probably need to replace the belt. Below I have listed a link to the owners manual which has instructions on how to change the belt and a link to the replacement belt you need. Hope it helps you!
Nov 01, 2009 | Eureka Capture Upright Vacuum Vacuum
Eureka vacuum cleaner
That means that the belt2_bing.gif is starting to wear. When the belt starts to stretch it can't turn the roller brush against the resistance of the carpet and therefore doesn't pick up well. You simply need to change the belt. Here is a link to the belt you need and to the manual:
Eureka 2961AVZ Belts
Eureka 2961AVZ Owner's Guide (3.4 KB download)
Aug 29, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Have eureka 9734 replaced belt, put back together,brush rotates well but vacuum is not picking up anything, no suction.
It sounds like the machine is clogged. Check the port behind the belt and any and all hoses for obstructions and remove.
Apr 13, 2009 | Vacuums
Vacuums Logo
421 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
