Question about MA Audio HK15X2 Car Subwoofer
Subwoofer cone catching
I have two 2400 watt FUBR Power Acoustic subs that I am having an issue with on one.…it is hooked to an 1800 watt JPL amp…everything has worked perfect for three years but now….
One of the subs internally is catching on something. When the cone goes in and out it is catching and clicking. There is no tear or wire pulled off, it is a physical part of the internal baffle (or cone or whatever it is) that is catching. It is only one spot inside but I cannot see it due to the surrounding metal (which is perforated).
Any ideas on what this is or if it is fixable?
Thanks for any help you can provide….
    Habit-Forming:
  • 59 Answers
From past experience this is usually due to the voice coil overheating and then hitting the magnet structure and producing a clicking sound when being played. Basically your speaker is blown.
Some brands of speakers have spare parts such as coils/cones for them to be repaired but probably not many now days.
Posted on Feb 15, 2008
Will a Lanzar Vibe 286 4000 watt amp push a power acoustik fubr 12 700 rms 1800 max ....
Yes it should do the job. You will need to wire the sub in series and make sure you have a 4ohm load on the amp. It should be right at around 700 watts RMS @ 12-13 volts.
May 18, 2012 | Lanzar VIBE266 Car Audio Amplifier
I had Rockford Fosgate P300-1 Amplifier installed professionally with a Kicker CVR10 10 in Subwoofer in 2010 Comaro. My problem is that it causes an odor in my car. I took it back to Mothers window tint...
your kicker cvr subwoofer should have a max power of 1600 watts therefore your amp is not too much for the sub because the p300-1 amplifier has a max output of 900 watts. if anything your amp would not be enough to produce max power out of your subwoofer. your sub should not produce an odor unless you have your amplifier bridged which doubles the watts pushed to your subwoofer and if that is the case your amp is pushing 1800 watts to a 1600 watt sub which could be causing it to fry or possibly blow soon. other than that if thats not the case there shouldnt be a problem.
Dec 31, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
What size amp needed with a sony explod player?
this bandpass enclosure is rated peak power at 1200 watts . what this means is that each subwoofer in the is peaked at 600watts to make 1200 watts . what your looking for is to power up the subs with rms continuous wattage . you need an amp that will put out 400 to 500 rms a channel to run this sub enclosure at 800 to 1000 watts rms to keep the speaker from blowing
audiopipe apf1801
71671968.jpg this amp will give you 1 channel @ 4 ohm x1 350 watts 1 channel @ 2 ohm x1 900 wats 1 channel @ 1 ohm x1 1800 watts you would have extra power for better subs with more power later but you get 900 watts which when connected right would mean 450 watts per sub be perfect for you . i sell this for $320.99 in my store can shipp any where in usa to contact me caraudioquestion@gmail.com
Oct 14, 2010 | Dual XINBP-210 Car Subwoofer
Why does my 6x9 amp drop or not let the sound play at all when my subs are on? it just started to happen? they worked together fine before. i turn the subs off and the 6x9 work? but when i turn the subs on...
You probably have too much hooked up for the size of your power supply which is presumably a small car battery. You either need to get:
A) New, better bigger battery.
B) Capacitor in series with battery.
C) Both of the above.
Mar 08, 2010 | Rockford Fosgate Punch Stage P212 S4 Car...
Hooking sub up
Hello missywarden,
According to the specifications, the amp is capable of "tri-mode" operation, that is, running normal speakers on the individual channels while also powering a subwoofer in bridged mode.
Your sub needs to be a minimum of 4ohms and should be relatively efficient. I'd look for a sub that has an RMS power range of from about 75 watts up to a maximum of 250 watts.
The sub connects to the leftmost speaker terminal (positive - right channel) and the rightmost speaker terminal (negative - left channel).
It's not going to be a really loud subwoofer. The power is 360 watts RMS which will be shared by the normal speakers and subwoofer.
Hope this helps.
Aug 05, 2009 | Power Acoustik TS620-2 Car Audio Amplifier
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Will it work together
put a the amp the max charge permitted, and y you have a preamp you can makeit work.
Feb 10, 2007 | Kenwood KAC-9102D Car Audio Amplifier
MA Audio HK15X2 Car Subwoofer Logo
88 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
