Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Dryer doesn't dry
Everything works, but there's no heat in the dryer. It just tumbles the clothes.
  • 3 more comments
  • bix777 Feb 14, 2008
    OK, I'll check the model number when I get home tonight. Thanks!
  • tonymyt Mar 24, 2008
    There is no heat in the dryer.
    Is there an internal fuse?
  • faypierce Apr 25, 2008
    checked the electric, bought a heating coil. Can I fix this from the front or do I need to do it from the back of the unit?
  • robert samples May 11, 2010
    to get to all the parts you need to check js you just have to remove the lower panel heater is up front to the right frigidare is behind the drum
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    If the header you are using is correct, I'm assuming this a stacked model washer/dryer combination. This symptom is usually an indication of a blown thermal cut-out or bad heating element. To repair, you are going to have to remove the dryer drum to get to the components. The heating element, which is a large coil, sits directly behind the dryer drum. The thermal cut-out sits right next to the heating element. Unfortunately, I do not know of an easier way to get to the components to check them without removing the drum. Can you provide me with your model number (located inside the door of the dryer) so I can make sure?
TAKE THE BACK OFF OF THE DRYER AND CHECK AND MAKE SURE THAT YOU HAVE POWER COMING TO THE ELEMENT WITH DRYER RUNNING IF SO THEN CHECK THE ELEMENT WITH A OHM METER AND SEE IF IT IS BROKEN, IF NOT MAKE SURE THAT THE THERMO DISK IS CLOSED WITH THE OHM METER, IF IT IS THERE IS PROBABLY A THERMO FUSE UP ON THE ELEMENT CAN THAT IS BLOWED.
Posted on Feb 28, 2008
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Frigidaire Galaxy Dryer tumbles but heats to dry seldomly
What is the model number of the unit?
Nov 13, 2012 | Dryers
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
Wt881 gorenje tumble dryer
Hello, I have a problem with the dryer, it doesn't dry to clothes off and everything else works fine. What seems to be the problem and how can I check it on my own? Is it the heather, the thermostat or something else maybe?
May 26, 2011 | Dryers
My Roper elictric dryer is not drying clothes
If you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some tihings to check before assuming there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call. If you check everything and still have poor heating issues, please let me know. You may have an internal bias or hi-limit thermostat malfunctioning.
Jan 05, 2010 | Roper RES7646KQ Electric Dryer
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
My GE dryer is tumbling & heating but not drying.
there may be heat but if your heating element is not working properly it will heat some but will not dry cloths
Nov 15, 2008 | GE DBL333EA Electric Dryer
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal De
