My daughter tried to clean my Projection screen with water. now i have a dark gray/black mark across the bottom of my screen can this be repaired
Hi Coyito,
We do have to love our helpful children. I know my grandchildren can always be so helpful. Smiling.
As for your problem, you can clean the screen by using a light soap and water solution ( like you would clean your windows ). If the water got onto the picture tubes on the inside of the set, you'll need to open the set up by removing the screws on the back panel as to expose the tubes and clean then in the same manner you clean the screen.
Make sure that before doing any of these procedures, make sure all the water that your daughter got into the set is dry ( this may take a few days) and while the set is drying don't use it and unplug the set. There may be some water on the main board causing a short and if you let the set dry up, it may work properly in a few days.
Good Luck and I hope this has helped.
Happy Presidents Day
Ed
NC Electronics
Mills, Wyoming
PS ( ALWAYS USE PRE CAUTIONS WHEN YOU WORK INSIDE THE TV SET BY UNPLUGGING THE SET FROM THE WALL BEFORE YOU DO ANY WORK ON IT )
