Tip & How-To about GPS
How to Reset Tom Tom One GPS
There are two methods depending on which version of the Tom Tom One you have (there are a few versions of the One).
Method 1
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Reset your device.
    Press and hold the On/Off button until your device comes on - shuts off and restarts. This can take more than fifteen seconds.
Method 2
Check the bottom of the unit to see if it has a Reset button which is recessed into a hole in the casing like this.
If so follow this procedure;
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
Hope this helps. Please do take a moment to register your vote for this Tip. Thanks.
GPS Logo
tom tom screen calibration for 9.510 Nav Core version
cant be done, if the touchpad is out of synch it needs to be replaced.
Sep 08, 2014 • Tomtom GPS
touch screen on tom tom one is out of alignment toward the top. bottom part of screen is ok.
I found this on the internet, hope it helps....
Touch screen Calibration.
Method valid for NavCore versions until 8.051.
A manual method to correct the calibration of the touchscreen input device of any all-in-one TomTom systems consists in creating a file called calib.txt (e.g., with notepad) and saving it in the main directory of the TomTom disk memory (e.g., the SD card; the same directory of the ttsystem file).
calib.txt should include one line with four numbers separated by a space: MaxX MinX MinY MaxY
Notice that the ‘x’ sequence (max, min) is inverted than the ‘y’ sequence (min, max). MaxX > MinX and MinY < MaxY.
For instance, the file can include:
928 118 107 912
Each TomTom device has its own most appropriate sequence.
In order to compile the file with default data, one method could be to perform a TomTom reset (or to eject the SD card), powering on the device and holding down the ON button for a few seconds until a unit status screen appears. The line named “Touchscreen calib. data:” will include four numbers that in sequence represent MinX MaxX MinY MaxY; these numbers can be used to fill the configuration line of calib.txt remembering to swap the first two ones. For example, if the unit status screen returns 118 928 107 912, calib.txt has to be saved with 928 118 107 912.
Tuning can then be done by adjusting these numbers until the touchscreen is calibrated. Distortions like screen rotation, trapezium and rhombus correction cannot be achieved with this method even if tuning these parameters can provide an acceptable touchscreen management even in presence of distortions; the best screen to tune the calibration is exploiting the soft keyboard of the NavCore application.
For instance, in my old TomTom GO Classic device I realized that, after activating the NavCore soft keyboard, when moving vertically (Y axis) the cursor appeared calibrated, while the horizontal movements (X axis) prevented to manage the left and right key columns (especially in the left bottom corner positions). So, I left the last two digits unaltered and, after some tests, I successfully used the following values: 805 200 107 912.
Method valid for NavCore versions post 8.051.
For NavCore versions 8.2x and 8.3x, use the same method as mentioned above, with these small differences:
the file should be named cal.txt (and not calib.txt) and should again be positioned in the main directory of the SD (or HD) drive of the TomTom system (e.g., the same directory where ttsystem can be found). Besides, the four numbers included in the file should have a different sequence than what previously described for versions until 8.51; cal.txt shall include the following sequence: MaxX MinX MaxY MinY (notice that also MaxY precedes MinY).
For instance, cal.txt could include the following four digits: 928 118 912 107
Again, these numbers are specific of each TomTom single unit.
E.g., my TomTom GO Classic correctly runs 840 245 912 107.
how do you reset the tomtom one
There are two method depending on which version of the Tom Tom One you have (there are a few).
Method one
Method 2
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
Hope this helps. Please do take a moment to rate the answer. Thanks.
cant get windows installer and java to open even after downloaded
Method 1
Unregister Windows Installer, and then reregister Windows Installer. To do this, follow these steps:
1. On the "Start" menu, click "Run:.
2. In the "Open" box, type "msiexec /unreg", and then press ENTER.
3. On the "Start" menu, click "Run".
4. In the "Open" box, type "msiexec /regserver", and then press ENTER.
Method 2
Upgrade to Windows Installer version 2 or newer version. To do this, follow these steps:
1. Start Microsoft Internet Explorer, and then browse to the following Microsoft Web site:
http://msdn.microsoft.com/downloads
2. In the left pane tree menu, click "Setup and System Administration", and then click "Setup".
3. Click "Windows Installer", and then click the appropriate link for your operating system.
4. Click "Download" to download and install Windows Installer version 2 or newer version.
Method 3
Use Windows Installer CleanUp Utility to uninstall the failed product.
Description of the Windows Installer CleanUp Utility
http://support.microsoft.com/default.aspx?scid=kb;en-us;290301
Method 4
The Windows Installer service may disabled on the machine.
1. Go to "Start" -> "Run" , type "services.msc" and press on "Enter" button.
2. Double-click on the service named "Windows Installer".
3. Check the value in the "Startup type:" field. If it's currently set to "Disabled", then this is the
problem. Change it by selecting "Manual" from the drop-down box.
courtesy:- support.microsoft.com
touch pad seem to be out of calibration - when you touch anywhere on the screen, it highlights about 1/2 inch above where you are pointing - very hard to enter addresses etc.
not sure what tom tom you have but try this (found in a forum)
SAW THIS IN ANOTHER FORUM - RESOLUTION TO SCREEN CALIBRATION ISSUE
So I will give it a try to help sort out a friends TomTom.
928 118 107 912
Top GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a GPS Expert? Answer questions, earn points and help others
