Question about EnGenius Lands Phones
Engenius EP490 I have an Engenius EP-490HC SEARS cordless phone. The phone keeps making a buzzing almost like vibrating sound even when the phone is turned off. When I press power on, the Welcome screen would display then it would flash goodbye.
SOURCE: Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Posted on Jan 21, 2008
SOURCE: EnGenius DuaFon 1X
deregister handset then reregister it
Posted on Mar 05, 2008
SOURCE: rotary tone on GE 6.0 cordless phone won't turn off
From the Handset Setup Menu:
1. Press the caller ID-volume ( 5 or 6) button to scroll to the TONE PULSE sub-menu.
2. Press mute/program button to enter the menu. TONE/PULSE 41TONE 2PULSE shows in the display. The default setting is “1 TONE”.
3. Use the touch-tone pad or caller ID-volume ( 5 or 6) to enter 1 TONE or 2 PULSE.
4. Press the mute/program button to confirm. You will hear a confirmation tone and your selection shows in the display.
Posted on Feb 09, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
SOURCE: one handset gives the message, blinking, Welcome!
I replaced the battery. It solved the problem.
Posted on Dec 21, 2009
My EnGenius cordless is not responding.You can not answer or make calls on it.I tried to turn it off-it's not responding
It has somehow unregistered with the base unit. Go to the base with your handheld. On the handheld menu, you can select "register". Try that by first. Next, press the gray (usually) button on the base unit and register the cordless again. If no go, de-register the cordless and try the steps again. Post for more if those did not work.
Feb 17, 2015 | EnGenius Lands Phones
Uniden model d1364 cordless phone buzzes, sounds like bad connection, when being used, how to stop buzzing sound
Try moving the base unit that the phone cord is plugged into. Keep it away from heavy power users like the microwave and refrigerator. You would also want to keep it away from other transmitters such as your wireless router. Also make sure the base unit is not near your power meter or circuit breaker box. Hope this helps. Good Luck!
Jun 10, 2014 | Lands Phones
Very loud buzzing
The sound can also be caused by a faulty outside line. You can bring in a different telephone (like one at your house) and see if the buzzing sound disappears. If not its either a line problem or a jack/wire problem.
May 11, 2010 | Telemania 027367 Spiderman Animated Phone
Constant Buzzing sound on recipients end
it might be due to EMI(electromagnetic interference). if other phones or internet lines r nearby, u can hear the buzzing sound.. if EMI is the cause, then its best to keep the phones isolated from the devices causing them. Good luck!!
Oct 04, 2009 | Uniden Cordless Phone
Phone sounds like going underwater, buzz noise when headset in
it sounds like u have fitted a cheap double phone line adapter try removing same and see if sound improves
Jul 21, 2009 | Panasonic KX-TG2431 Cordless Phone
Speaker phone volume keeps going loud and quiet
Did the location change, a Echo from a wall or vibration from the table. It is a one way sound, someone talks and you hear. As soon as you talk it cuts out the speaker even if they are still talking and it transmitts what you say. So any noise in the room could trigger the the transmit mode even an echo from the sound being turned up too loud. The mike is on the bottom of the base and can pick up table vibration and send it into transmit mode. So the person talking cuts in and out.
AL
Jan 15, 2009 | Sony SPP IM977 Cordless Phone
Buzzing noise from speakers
The buzzing noise is being heard probably because there is another electronic device around that's using radio waves to function. (Such as a cell phone, a cordless phone adapter or a wireless router. Even microwaves and ceiling fans can give off these sounds.)
My advice would be to try and move around or turn off some appliances in your room that may give off radio waves.
Sep 18, 2008 | Logitech Z-2300 Computer Speakers
Ac adaptor was dropped on ground, and makes a BUZZING SOUND. Is it safe to still use
It may not hurt anything; the transformer in the adapter has iron laminations which are normally potted with epoxy to keep them quiet as well as stabilising their magnetic characteristics. Dropping it has caused one or more laminations to come loose but it probably won't affect anything. You might feel the adapter now and then for a few days to ensure it is not running hot; warm is OK.
Sep 06, 2008 | Uniden 5.8GHz Dual Cordless Phone
Cordless phone EnGenius SN 920
. A new handset arrives with a handset ID number of 00, to register this handset to your system take the following steps:
  1. On the EnGenius base unit press and hold down both the "Volume" & "Intercom" buttons for about five seconds. You will hear a beep from the base unit. You can now release the two buttons.
  2. On the EnGenius handset (00), press the following buttons: "menu", "6", "1".
  3. A new handset ID number (ie: 12, 13, 14…) is automatically assigned by the base and registration is complete.
Feb 29, 2008 | EnGenius SN 920 Ultra Cordless Phone
Lands Phones Logo
83 people viewed this question
Top EnGenius Lands Phones Experts
Eric Sutherland
John L radiodude365
Bill Boyd
Are you an EnGenius Lands Phone Expert? Answer questions, earn points and help others
