Question about Lexmark X5470 All-In-One InkJet Printer
Carrier jam My lexmark x5470 has an error message saying "remove jam from carrier". there isn't a jam but the message won't go away, even after following the steps.
  • 3 more comments
  • micky08 Mar 02, 2008
    I have a lexmark x5470 has an error message saying "clear carrier jam . there isn't a jam but the message won't go away.
  • riverview Mar 04, 2008
    I have the same problem making me unable to print anything I jsut bought this printer no even a month ago please help
  • angel418 Mar 14, 2008
    printer says clear the carrier jam and there is no jam
  • samdean May 01, 2008
    I have this "clear carrier jam" , tried everything I could think of, there is no paper anywhere in the paper path. may be it's a faulty sensor?
  • bwheeler7 Feb 10, 2009
    it keeps saying carrier jam
I had paper stuck in scanner part,that fixed my problem with Carrier Jam.
Posted on Aug 11, 2009
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
855
Posted on Mar 02, 2009
    Problem Solver:
  • 6 Answers
Try feeding a sheet thru the top mutisheed scanner feed, or look for some paper stuck in the rollers, I have had mine jam up on multisheet copies several times and I get a clear document type error.
Posted on Mar 12, 2008
SOURCE:
Lexmark 5470 says: incorrect right cartridge. I have insert new lexmark cartrdge no.35, after that anew cartridge lexmark no.33, and the printer says the same, even when the carrier is empty. I have...
Try to remove both black and color cartridges from the printer. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert both cartridges and make sure they are properly seated and secured in the carrier. Close the cover. If error continues to show on the display screen even if interchangeably insert your 35 or 33 cartridge, please contact Lexmark Technical Support Center for additional assistance.
Jun 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Carrier jam
From what you are saying you are getting 'clear carrier jam' because of a misalignment. The jam error message is a generic message that applies to a multitude of things. The carrier while is in right, might not be sitting right. A piece of plastic that holds the carrier might be broken or the printhead might be messed up. Anything that causes it to not sit the way it wants will cause that error message.
Feb 10, 2009 | Lexmark X4270 All-In-One InkJet Printer
I have a carrier Jam!? It a lexmark x5320 I have tryed everything nothing works.
In this case unplug the Power Supply from the Printer...............
Take Out both the catridges from the Printer.................
Move the Catridge Carrier which holds the Catridges inside the Printer from left to right and from right to left for about 20 Times.......................
now insert both the catridges inside the Printer and Plug in the Power Supply and see whether you get the error message again.................
If u still have that error message please Call lexmark:
1-800-LEXMARK (539-6275)
Just call this number because the Enchoder strip has to be replaced........
Good Luck
Jan 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
Ran system suite 8 and now printer isn't working
my printer lexmark x4550 when switched on it says Clear Carrier Jam, then press tick so i dont know what's that means, thanks
Nov 22, 2008 | Lexmark X5470 All-In-One InkJet Printer
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark X5470 All-In-One InkJet Printer Logo
1,338 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
