Question about Night Owl Optics Light NOLT3 Monocular
Need in assistance in repair
I took apart my night optics and i think there is problem with circuit board i think i need change fuses
Help me. Please.
I did the same thing and found that the solder from the battery tray and the circut panel came apart. Check it out. Just somthing to check. Good luck
Posted on Mar 18, 2009
  • ebaymaniax Apr 01, 2011
    dear expert
    i had problem with my NOLT3, need help please
    it won't stay ON, i had to keep pressing the power button to make it HOLD ON.
    every time i release the power button the unit goes OFF.
    what happen with this unit?
    please let me know.
    thank you very very much.
Contacts bad in the on/off switch. Won't turn on. Tried cleaning contacts on circuit board and rubber parts with alcohol. Did not help.
depends on the damage, water can be on circuit board. your insurance should pay for repairs if they bought it for you. try finding a used one on the internet, but you are taking a risk.
Aug 09, 2012 | Golden Technologies Alante 2 Heavy Duty...
I have a STVD-919 that at times freezes up than starts again, freezes up putting words on top of each other. Will never buy another Singing Machine second one with problems and company has no place to...
These are rare model with a limited service support and it is important that you need to get this part ONLY if the failed unit has a universal replacement which must be checked physically with any electronic showroom. If this is not properly confirmed please do not spend any more money on it as a replacement also can be short lived if the quality of spare is poor.
Dec 06, 2011 | The Singing Machine Audio Players &...
I took out 3 lenses but there is still one inside and it has a fingerprint on it that i would like to clean & i can't reach it because it is on the inside, don't know how it got there... &...
It is a wigit finger print. Anything that happen, does happen, could happen, will happen, happen to disappear, you can count on it that a darn wigit had something to do with. There could be more than one wigit also.
The optics on you Night Owl are Russian manufactured. So, it a Russian wigit finger print.
Now which optics lens has the finger print, viewing optic, 50mm input optics. So you need to tell me which optics and I will help you remove the lens by written instruction OK. I have a Night Owl NOCX3 setting on my work bench. stewbison
Aug 14, 2011 | Night Owl Optics Explorer NOCX3 Monocular
Hi my tv fell off the wall last night about three feet to the carpet now it won't turn on the amber vizio light won't even come on when I plug it in. I took it apart and nothing appears to be...
After a fall like this (even on carpet) it probably has a cracked circuit board or a loose connector, first (since you took it apart any way) look for all connectors, than unplug them and re-plug them to make sure all plugs and boards are seated correctly, if you still don't have luck, than take out all the circuit boards and check them for cracks under a good lamp and magnifying lens, than repair the cracked traces with a good soldering gun by scratching off the varnish coating and applying solder. (if the crack is to wide you can solder a peace of coper wire to the trace on the board)
Have fun!
Jun 25, 2011 | Vizio L32 32 in. LCD HDTV
The lamp that lights the LCD display at night on the Radio control panel has gone out. I took the unit apart and found that the light is soldered on to the touch key circuit board just behind the face of...
You need to locate a company that specializes in repairing car radios. They are few and far between. The only one I know of, and I'm not sure they are still in business, is Downtown Radio in Charlotte,NC. They were an authorized Delco repair facility.
Jun 12, 2017 | 1999 Toyota Camry
Proscan lcd tv model 26lb30h blows fuse on power board
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Jun 20, 2009 | Proscan 26LB30H 26 in. LCD TV
TV won't turn on
Hello Marie,
I am sorry to hear about your situation. Most tv's do have an internal fuse, so if you open the chassis (which is the back part of the tv and slide it out and away from your circuit boards) the fuse will be located where the cord comes into the circuit board. Look for burnt or scorched spots on your circuit board also while you have the back off. I am sorry to say that most often than not in cases of lightning strikes the damage is expensive to repair and replacement of the devices is usually cheaper. Since the strike got a lot of your devices, it is not looking good. If you have further questions or need more assistance please let me know and I will be more than happy to help.
If you do not mind please rate my help, I would appreciate it. Thanks
Aug 13, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
Please help...hubby misses TV
take the front speaker cover off and unhook the circuit board for the buttons its like a 7 pin connector our's did the same thing and we spent 200.00 getting boards soldered just to bring it home and it still flipped thru channels and then shut off. I took the circuit board off and it works fine.
Oct 26, 2006 | RCA P52960 52" Rear Projection Television
NEED WIRING HELP FOR NIGHT OWL OPTICS
No. Night Owl Optics in El Paso, TX. want send me schematics, parts, etc. Get back to in about a week I might be ability to find hand drawn wiring diagrams. Now I am saying I can look, I am not I do, OK. stewbison
Sep 07, 2006 | Night Owl Optics Discovery NODS3 Monocular
Night Owl Optics Light NOLT3 Monocular Logo
202 people viewed this question
Top Night Owl Optics Optics Experts
wadingriver
wadingriver
ray gallant
Are you a Night Owl Optics Optic Expert? Answer questions, earn points and help others
