RCA Lyra RD1072 MP3 Player Logo
Posted on Feb 14, 2008
Memory Whats the memory for the RCA Lyra RD 7072A?
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Feb 29, 2008
Anonymous
Contributor
Level 1:
Answers
34
Questions
Helped
4301
Points
38
I believe that it is 256MB as that is how much mine had when I owned one.
Also if you need more memory you can insert a SD card to expand its memory.
I lost my lyra rd 1076A software cd and i want to install the software on this computer where can i get it?
Did you ever get your software? I did find out you can use Explorer to transfer files to the removable device or use sync in Windows Media player. However I don't know how to access a memory card.
My RCA lyra RD1076C wont play songs from the memory card
FAT32 is not compatible with the Lyra, you must use FAT not FAT32
MY RCA LYRA RD 1076A MP3 PLAYER WONT PLAY SONGS WHEN LOADED ONTO A MEMORY CARD EVEN THOUGH IT SHOWS THE CARD IS FULL. HOW DO I GET IT TO PLAY?
The player can only handle cards of a certain size, usually 1gb or less. I would go back over the user's manual and make sure you followed the instructions to the T.
Memory
I have this same problem. Very frustrating.
2helpful
2answers
Memory Card
a Standard SD card will work
Rca lyra memory card
Maximum memory upgrade is 512Mb.
My RCA Lyra RD 2762B Show: Please UPgrade
I NEED THE SOFTWARE FOR A RCA LYRA RD2762B MP3 PLAYER, IF SOMEONE HAS IT CAN YOU PLEASE HELP ME OUT. PLEASE SEND THE INFO TO [email protected]
6helpful
7answers
My rca lyra rd1080b
this is the best solution you have update your lyra rd 1080/rd 1090 for download the updating click her http://download.rca.com/download/RD1080_90FWUpgrade_v4.26.exe and after instaling this update follwo instructions provided below ? To update your Lyra RD1080/RD1090, make sure you have it connected to the computer via the included USB cable. You will need to make sure that no external memory has been inserted and the Lyra RD1080/RD1090 display reads: "USB Connected Int. Mem". (If it does not, please refer to the users guide for the section on how to switch between internal and external memory.) ? Once connected, locate and run the Lyra Systems File Update Utility if it didn't open automatically. Installshield Wizard will have automatically created this icon on your desktop as well as under "Programs", "Lyra Personal Audio Player", "RD1080/RD1090" in your START menu. ? Click the "Refresh" button until the RD1080/RD1090 player shows up under device. ? Once displayed, highlight the drive letter by clicking on it, and click the "Update SYstem Files" button. ? When successfully completed, you will see the message, "The Lyra Personal Audio Player Device system files were successfully updated." ? Click the "OK" button, and then "Done". This will close the Lyra Systems File Update Utility. ? Disconnect the Lyra RD1080/RD1090 from the USB cable, turn the unit off and back on.
SD memory problems
Try inserting the memory card first, then plug the player into the computer.  Worked for me.
Problem using Scan Disk memory card
I had the same problem, and that is what RCA answer me: "... Due to a unique FAT12/16 cluster size requirement, the supplied format utility that comes with the RD1021/RD1071/RD1075 MUST BE used on all SD/MMC cards before they will work in the RD1021/RD1071/RD1075. Once formatted, these cards will still be FAT compatible and should still work with other devices, i.e. RD1080. The format utility can be found under "Programs", "Lyra Personal Audio Player", "RD1021,RD1071,RD1075", "Format Media" once your software has been correctly installed from the included RCA CD-ROM. ..."
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
